Grips?
  • Kauzenkaos
  • Kauzenkaos's Avatar Topic Author
Grips?
13 May 2016 21:12
#726304
Do you guys know who makes these grips? The cruise control lever has n.e.p. on it but i couldnt come up with anything. I was looking to just replace the worn out foam.
  • punisher11b
  • punisher11b's Avatar
Re: Grips?
13 May 2016 21:38 - 13 May 2016 21:44
#726308
I'm not sure you can replace just the foam on those guys. They kind of look like the cheap foam replacement grips that my 305 had.
- good luck
Last edit: 13 May 2016 21:44 by punisher11b.
Re: Grips?
13 May 2016 21:55
#726312
An ebay search for foam motorcycle handlebar grips produces several similar grips (inexpensive).
Good Fortune! :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Kauzenkaos
Re: Grips?
14 May 2016 08:10
#726365
Ok ill take them apart. I thought the cruise was part of the grip.
Next im on to the speedo. The P. O. said that it stopped working. I undid the cable at the speedo head last night when i slid the fork tubes down to test fit my new headlight assembly and found that the cable is good and turns when i spin the front tire. Has anyone had any success repairing the head for this problem?
