GSXR Front Axle Diameters?
- Kray-Z
- I need more power Scotty....
05 May 2016 14:59 - 05 May 2016 15:10
Hey,
Anyone know what OD the front axles are on a 2008-2013 GSXR600/750/1000 front wheel is?
I measured a 2005 GSXR1000 and it is 25 mm, which is what I need to match up to my ZX12R front forks, but I wanted to use the newer style GSXR front wheel (the twisted looking 3-spoke type). The 2008 and up 600 axle looks smaller then the straight spoke 2007....
Last edit: 05 May 2016 15:10 by Kray-Z.
Re: GSXR Front Axle Diameters?
05 May 2016 20:57 - 05 May 2016 21:05
From the front wheel diagram at Partzilla for the 2008 GSX-R1000, the wheel bearings are 25mm I.D. I looked at a couple of other models & they are the same. you probably ought to check the bearings of the specific donor bike, just in case they're smaller.
09262-25061 B1 25X52X15 BEA (bearing)
Last edit: 05 May 2016 21:05 by martin_csr.
The following user(s) said Thank You: Kray-Z
- 650mod
06 May 2016 06:10
Here's another one to hopefully help a bit. Control F to find any bike. I used this on my build as well.
www.dotheton.com/forum/index.php?topic=20952.0
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- Kray-Z
06 May 2016 16:08650mod wrote: Here's another one to hopefully help a bit. Control F to find any bike. I used this on my build as well.
Thanks,
I already looked at that one, but couldn't find the model of Sue Zuki I was after...the list isn't completely current...
- Kray-Z
06 May 2016 16:10martin_csr wrote: From the front wheel diagram at Partzilla for the 2008 GSX-R1000, the wheel bearings are 25mm I.D. I looked at a couple of other models & they are the same. you probably ought to check the bearings of the specific donor bike, just in case they're smaller.
Thanks, I forgot how useful Partzilla is for cross reference! I hope they are correct, as the wheels for this swap are going to set me back $750.00 min...
06 May 2016 17:09
Before spending that kind of money, I would go to or call the Suzuki dealer.
- Kray-Z
07 May 2016 10:29martin_csr wrote: Before spending that kind of money, I would go to or call the Suzuki dealer.
Do you want to hear crazy? My local Suzuki dealer doesn't have an official service department (at all) - no professional mechanic. They farm any warranty work out to anyone they can find to do it!
They will tell you any BS that comes to their minds just so you will go away and not come back...Unless you are buying a new bike, they don't want you taking up their precious time. Nearly all around here are like that. Good service and parts people are leaving the area or getting out of the trade because of the BS they have to put up with.
Another reason why I don't do business with the local shops....
- pete greek1
07 May 2016 12:34
All of these models use the same front axle
Part # 54711-41G00
This part is also used on the following Suzuki models and components:
2010 GSX-R750 FRONT WHEEL
2010 GSX-R600 FRONT WHEEL
2009 GSX-R750 FRONT WHEEL
2009 GSX-R600 FRONT WHEEL
2008 GSX-R750 FRONT WHEEL
2008 GSX-R600 FRONT WHEEL
2008 GSX-R1000 FRONT WHEEL
2007 GSX-R1000 FRONT WHEEL
2007 GSX-R750 FRONT WHEEL
2007 GSX-R600 FRONT WHEEL
2006 GSX-R1000 FRONT WHEEL
2006 GSX-R750 FRONT WHEEL
2006 GSX-R600 FRONT WHEEL
2005 GSX-R1000 FRONT WHEEL
Pete
Part # 54711-41G00
Pete
- Kray-Z
07 May 2016 14:07
Thanks!
I'm going to find out for sure tonight, hopefully. jberger635 is the crew mechanic for a 2009 Gixxer 600 proddie race bike. He's changing tires and going though the suspension for the upcoming Brainerd race, so I'm going to drop in and check the spindle sizes on that...
I'll post what I find....
- Kray-Z
09 May 2016 14:06
Hey,
I had a buddy measure the front axle diameter on a 2009 GSXR600 and it is 22 or 23 mm (stated by him as near 0.900" - I wasn't the one holding the dial caliper) thru the bearings, certainly it is smaller than the 25 mm diameter of the previous generation of GSXR's. I think the 750 is 23 mm also...
Either way, it won't be a straight swap into my ZX12R forks....damn!
