Gap on rear axle
- Shdwdrgn
Gap on rear axle
03 May 2016 07:41
1981 KZ1000, I'm doing temporary reassemblies on the wheels and have about a 1 inch gap on the rear between the swingarm. On the chain side there is a spacer about 1" thick. On the other side there is a spacer about 1.25" wide with a stepped ledge, plus what looks like a really thick washer (which I think is supposed to go outside the swingarm, beneath the crown nut). The parts diagram doesn't show any other pieces outside of the bearings, so am I supposed to compress the swingarm when I tighten down the axle nut? Did I miss something?
(And yes, I see that the axle and crown nut are supposed to go in from the other side)
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
- nitrokeeb
Re: Gap on rear axle
03 May 2016 07:46
Your brake caliper fits on that side of the axle, does it not?
1978 KZ1000B LTD w/KZ900 engine
- Shdwdrgn
03 May 2016 07:54
Brakes? I'm supposed to have brakes on this thing???
Well crap -- found the piece you mean in some old pics, that certainly explains the large gap. Guess I would have figured that out once I got the rest of the pieces cleaned up and bolted on, but it's been a couple years since it all came apart.
Thanks for the quick answer. Now I can stop worrying about that and get back to work.
1981 KZ1000-JK1
- spdygon
03 May 2016 11:03 - 03 May 2016 11:04
Brakes...lol
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Last edit: 03 May 2016 11:04 by spdygon.
