engine swap
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
engine swap
26 Apr 2016 11:24
#723079
Can a engine from a 76 or 77 kz900 bolt into a frame of a 1981 csr 1000?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: engine swap
26 Apr 2016 16:08
#723128
It can be made to fit but it's norpt a simple unbolt the old one a d bolt in the new one. The J-model series engine (like comes in the 81+ bikes) use a different mounting setup.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • floivanus
  • floivanus's Avatar
Re: engine swap
26 Apr 2016 17:46
#723139
The J motor are also upgraded, the head breathes better, trans is beefier, better motor IMHO. Get a J motor if you can
Past; 78 kz1000, 83 kz550
Andrew
  • bromz
  • 1981 kz1000 csr
Re: engine swap
26 Apr 2016 18:20
#723145
I only ask cause I have the 81 and a friend would like the bike to put his older engine in. How much fab work does it take to adapt the engine into that frame??
  • floivanus
Re: engine swap
27 Apr 2016 05:26
#723200
You need to fab new front, and rear motor mounts along with making a complete NEW bottom mount (81 and up models have no bottom motor mount) this doesn't take into accound lining the motor up correctly for chain pull and all else, would likely need to get measurements from a pre 81 model and see if you can get the output shaft to swingarm pivot in the same alignment. One way works (J motor in kickstart frame? Or kickstart motor in J frame? I'm not sure, the other way is a lot more involved due to size differences)
Like I said, may be easier to find the correct replacement for the bike.
Andrew
