Tachometer
- Unz
Tachometer
24 Apr 2016 10:08
Can you put a digital / LCD clock on one of these beasties ? My tach cable comes from the front wheel BTW ,
Its a gt/kz750 four, p1 maybe (I'm not sure what it is , pmsl
- missionkz
Re: Tachometer
24 Apr 2016 10:48
Your engine RPM comes from your front wheel?
I'm going to assume that was an error your statement.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Unz
Re: Tachometer
24 Apr 2016 15:56
Doesn't a tachometer tell you your speed ? If not my speedo cable comes from my front wheel
I don't have a rev counter cable coming from my engine .
Re: Tachometer
24 Apr 2016 16:01
Connect it to the speedo. The tach might be electrical.
The following user(s) said Thank You: Unz
- Unz
Re: Tachometer
24 Apr 2016 16:30
I was just wondering if there are digital one's that fits straight on or if I have to buy a new old mechanical replacement? Mine work I think but 1 glass is broken and they're tatty anyway.
Thanks
Thanks
Re: Tachometer
24 Apr 2016 17:30
Is the bike a GT750 Shaft? Can you post pics of your meters & front wheel speedo drive?
Your bike probably has a mechanical drive speedometer & electronic tachometer. There are a few 1000 models that have an electronic speedometer, but they still have a large mechanical drive unit at the front wheel along with a speedo "cable". The Kawasaki electronic tachs from back in the day usually have a sensor wire connected to one of the wires going to the ignition coils. There are electronic speedometers that can be retrofitted, but i don't know much about them. They usually have a sensor that has to be installed at the front wheel.
- Unz
Re: Tachometer
25 Apr 2016 05:46
Hiya martin
Yup I'll sort some pics tonight and put em up when I get home
Thanks
Thanks
- Unz
Re: Tachometer
27 Apr 2016 12:07 - 29 Apr 2016 05:01
Your bike has the standard type meters & speedo drive gearbox. the speedometer ratio is probably 2240 revs = 1 mile. that info may be stamped in ink on the back. the speedo drive may need repair or replacing. The tach drive appears to have been damaged & disabled. not sure. ??? ... FYI. the pilot cover between the meters is the same as the 81-83 KZ650-CSR.
You'd probably need an aftermarket speedo with a ratio that's listed as 2240@60mph or 60kmh = 1400RPM. or something like that. I guess wiring up an electronic tachometer ought to be straight forward. I guess get one that has a signal/sensor wire that connects to one of the ignition coil wires.
just throwing it out there. aftermarket speedometer gauge set w mech speedo & elec tach. ZRX 1995-2008
these could be cheap junk. not sure, but likely. ??? .... oem meters might could be swapped in later. ???
Last edit: 29 Apr 2016 05:01 by martin_csr.
- Unz
Re: Tachometer
28 Apr 2016 06:14
Really nice, thanks martin, the clocks in the link look sweet as,
Oh and yes it is shaft driven. But still not sure if it's a kz750e as the engine numbers suggest or if it's a bitsa! I was told it's half gt half plastic pig (reliant)
- Unz
Re: Tachometer
28 Apr 2016 10:00 - 28 Apr 2016 10:03
Another option. the late model KZ1000-P Police meters would probably be a decent match. sold in the USA up to 2005.
note: your meters may not be stock. I have no idea as the GT 750 wasn't sold in the USA.
Engine numbers. I think the factory shaft drive engines begin with KZ750NE.
At cyclechaos.com the 750-N Spectre & 750-F1 Ltd shaft are listed thusly.
The chain drive engines begin with KZ750EE. including the later decades' ZR750 air cooled models.
Last edit: 28 Apr 2016 10:03 by martin_csr.
