kz1100 final drive repair
  • havakaw
  • havakaw's Avatar Topic Author
17 Apr 2016 07:38 - 17 Apr 2016 07:55
#721389
So the final drive on my 82 kz1100A2 Shafty has decided it wants to try to kill me by leaking the gear fluid on to the rear tire. Has anyone ever changed the seals on these? Should I just get a new/different one? Give it to the shop and let them fix it? How involved is it? Thanks.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Last edit: 17 Apr 2016 07:55 by havakaw. Reason: misspell
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: kz1100 final drive repair
17 Apr 2016 08:38
#721399
havakaw wrote: So the final drive on my 82 kz1100A2 Shafty has decided it wants to try to kill me by leaking the gear fluid on to the rear tire. Has anyone ever changed the seals on these? Should I just get a new/different one? Give it to the shop and let them fix it? How involved is it? Thanks.
For the cost to replace one seal, you may find an entire low-mile unit on ebay, with no leaks. Removing the old unit will be necessary regardless, so the choice is a no brainer IMO. :)
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
  • havakaw
23 Apr 2016 07:29
#722511
Well, after I got the rear wheel off and cleaning everything up, I discovered that the large outside seal had just gone bad. So I went to the bike shop and ordered a new one, along with the drain plug crush washer. While I had everything apart, I took the rear brake hose down to Empire Radiator, where they made up a new red braided line. The old seal was a little tuff to get out, but taking my time I got it free,cleaned up the area, and installed the new seal. Got everything put back together,filled up the unit with some vintage 1987 Kendall 80w90 Special Limited Slip gear oil that I had (brand new sitting on a shelf for 30 years) fired it up and did a running test while it was up on the center stand. No leaks!!! I let it sit overnight,checked it again,No Leaks!!! I did a 30 min test drive around town and no leaks!!! So for about $30 for the seal and washer, I'm back in business. Yea me!
'80 KZ 750 LTD-H
  • TexasKZ
  • TexasKZ's Avatar
23 Apr 2016 07:48
#722514
:woohoo:
  • KZB2 650
  • KZB2 650's Avatar
23 Apr 2016 07:58
#722517
Hell yea I do all my work too (except changing tires)..... one shop I would trust but still it wouldn't be cheap the others I would have to take out a loan and not really trust who they would put on it.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
