Center stand problem. Wrong spring?????
- car5car
- Banned
31 Mar 2016 12:26
I installed center stand and spring.
Center stand is hanging on spring and jumping. Spring is not holding it tight and can get disconnected.
If I move center stand up, it touches swing arm.
I'll take pictures in a few minutes
96 Yamaha Royal Star
82 Yamaha Virago 920
- RonKZ650
Re: Center stand problem. Wrong spring?????
31 Mar 2016 21:22
The stock left pipe is used for the centerstand stop to keep it from going up too high. You'll at least need to improvise a stop of some fashion if not running the original exhaust.
The following user(s) said Thank You: car5car
- daveo
31 Mar 2016 22:12car5car wrote: I installed center stand and spring.
After sixteen years of riding with it, I now have the center-stand removed until needed to service the bike, after finally realizing how much better the bike handles corners without the thing scraping on the pavement. That is, since a V&H street header was installed a few years ago, and I just pulled the stand off this Spring...easy with the less-obstructive header.
1982 KZ1100-A2/1170 sleeper 😀
