Rear brake pedal doesn't go up completely.
- car5car
- Banned
28 Mar 2016 12:26
I installed bungee cord. It is red like my bike. (There is no extra charge to buyer of my bike, bungee cord is included for free)
I couldn't find parts diagram for 80 KZ1000 shaft.
I found diagrams for other models, brake pedal is different.
There is no spring except switch spring.
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Rear brake pedal doesn't go up completely.
28 Mar 2016 14:22
The parts fishe online suck a big one and don't show an illustration of the parts, but I've never seen a rear brake lever that didn't have a spring. I'd remove the lever and grease the pivot shaft for starters, and find that spring.
- G-Force
28 Mar 2016 20:08
I had the same thing happen.Clean and regrease the shaft.
29 Mar 2016 05:18 - 29 Mar 2016 06:55
In the brake pedal diagram at Partzilla for the 1000-E2, part #92081-1116 is listed as unavailable in parts book. 92081 indicates that the part is a spring. If you search the part number on eebbaayy, there are several listed. Also in case something has been modified, I would also search for the brake pedal shaft to see if what's listed on eebbaayy is the same as yours.
Last edit: 29 Mar 2016 06:55 by martin_csr.
The following user(s) said Thank You: car5car
- car5car
- Banned
29 Mar 2016 06:49 - 29 Mar 2016 09:08
Martin, super!
You can read what is not written!
The spring is only used for 79-80 KZ1000 shaft.
I found place where the spring should be. It is missing, no broken pieces, nothing.
One of ebay listings for the spring says it is the same spring PN 92081-1116. It is available everywhere.
Attachment IMG_1301.JPG not found
Attachment IMG_1300.JPG not found
Attachment IMG_1297.JPG not found
Last edit: 29 Mar 2016 09:08 by car5car.
29 Mar 2016 07:20 - 29 Mar 2016 07:24
79 80 KZ1000 E1 E2 ST SHAFT REAR BRAKE 43004-1008
. appears to be the same.
NOS --- 43004-1008 .
ps: I would install a new cotter pin or hitch pin. ss if possible.
Last edit: 29 Mar 2016 07:24 by martin_csr.
- car5car
- Banned
29 Mar 2016 09:06
Thank, I will. There should be a washer probably, it is missing.
