kz750 rear wheel
- gixxerkidd03
kz750 rear wheel
21 Mar 2016 18:49 - 21 Mar 2016 18:52
ok so i've done some research on my options for a rear spoke wheel w/ disc for my 81 kz750e/h.
im currently swapping a 2005 GSXR 1000 front end and will be lacing up an new 18" front wheel.
i really want to lace up a matching rear rim and maintain my rear disc. i have seen suggestions on a possible 1000a wheel or 750b. i'm not excepting any of this to happen without a little work but i'm trying to find some one who has done something that will work for me.
bottom line is im looking for a rear disc hub i can lace up with a new rim, any after market rear hub that may work for my 81 kz750.?
any suggestions/advise/leads will help,i am just looking to get a matching 18 inch wheel set
Eric
Eric
Attachment image-2-3-4.jpg not found
1981 KZ750e
Last edit: 21 Mar 2016 18:52 by gixxerkidd03.
- gixxerkidd03
Re: kz750 rear wheel
22 Mar 2016 21:33
Common someon has to have a solution for a spoke rear wheel on these bikes? No?
1981 KZ750e
23 Mar 2016 04:51 - 23 Mar 2016 04:55
What front wheel are you going to use? The only 18" Rr w disk that I know of are the two you mentioned already ---- 1000A & 750B. I think those are 40-spoke. The 1000 CSR has a 48-spoke 16" Rr. I would assume an 18" rim could be laced to the csr hub, but its hub might be wider than an 18" hub.
Last edit: 23 Mar 2016 04:55 by martin_csr.
- DoctoRot
29 Mar 2016 10:24
There probably isn't anything that is bolt on. but you might get lucky with the wheels you previously mentioned. If i was going to upgrade the front suspension I would do the rear as well, the soft stock shocks and spindly swing-arm are going to disappoint after slapping a modern front end on there.
