How to check swing arm bearings?
- car5car
- Banned
17 Mar 2016 19:12 - 17 Mar 2016 19:14
I tried to find a part diagram for 80 KZ1000E.
Is it in frame? Which diagram?
36 years old bike, is it time to replace?
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 17 Mar 2016 19:14 by car5car.
- RonKZ650
Re: How to check swing arm bearings?
17 Mar 2016 19:26
They used two heavy duty, good quality roller bearings. Like all the KZ1000E parts, basically the best of the best quality and heavy duty, made to last. I wouldn't worry about the bearings unless you're up in the 200,000 mile area. Age doesn't matter to a bearing.
17 Mar 2016 19:27
Greas them.
- PLUMMEN
17 Mar 2016 19:48It matters if theyve never been greased! :laugh:RonKZ650 wrote: They used two heavy duty, good quality roller bearings. Like all the KZ1000E parts, basically the best of the best quality and heavy duty, made to last. I wouldn't worry about the bearings unless you're up in the 200,000 mile area. Age doesn't matter to a bearing.
17 Mar 2016 19:52
True.
- davido
18 Mar 2016 00:24
If I remember right,back in the day,Kawasaki swingarms had a reputation for drying out bearings.So much so that people would drill a hole under the pivot area and thread in a grease nipple.
Maybe an urban legend but twas one of those things,like Yamahas were known for seizing brake calipers and Suzukis for bad electrics and Hondas for dodgy camchain tensioners.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- GKBO
- Saving old"dead" bikes
18 Mar 2016 03:33 - 18 Mar 2016 15:37
Dealing with the aftermath of what happens when the swing arm bearings aren't greased. on my 82 GPz750.Those nice heavy duty roller bearing can be turned into so much rust.Got to replace the sleeve,bearings and the pivot bolt because it was so stuck it had to be pounded out.Unlike your KZ1000 most of those parts are NLA from Kawi :S Swing arm and shocks have they're own fiche on the ones I've looked at.Yes I'm going to ad a grease nipple to the swing arm.
Last edit: 18 Mar 2016 15:37 by GKBO.
- car5car
- Banned
18 Mar 2016 06:23
Do I have to remove drive shaft to grease left bearing? (shaft model)
18 Mar 2016 06:34
Isn't it lubricated internally? My grease zerk was backwards so I couldn't get to it. Got another one that would face the right way, by that time the damage was done.
- RonKZ650
18 Mar 2016 06:54
You guys are all talking of other motorcycles which use either a sleeve and bushings or a sleeve with little needle bearings. Yes these need lube quite often, and even then aren't heavy duty. The shaft used real roller bearings. Not to say they don't need lube, but chances of them being in bad shape is definitely less than on other Kawasakis.
They built everything on the shaft heavy to last, then in 1981 went to the KZ1100 shaft and all heavy duty was replaced with regular duty parts.
18 Mar 2016 07:04Steve
- GKBO
18 Mar 2016 15:48Opps looked closer at the PO's sig.The shalft drive would make a huge difference obviously..The way it's set up on the chain drive is stupid without a grease fitting.Getting 4 bearings for the GPz and thinking I'm going to use all 4,yes they'll all fit.RonKZ650 wrote: You guys are all talking of other motorcycles which use either a sleeve and bushings or a sleeve with little needle bearings. Yes these need lube quite often, and even then aren't heavy duty. The shaft used real roller bearings. Not to say they don't need lube, but chances of them being in bad shape is definitely less than on other Kawasakis.
