KZ400 rearsets
- Sims426
KZ400 rearsets
15 Mar 2016 11:36
I'm swapping the stock KZ400 arm for a 2010 ninja 250 swingarm and rear wheel. I've searched around and only people who have made rearsets for drum brake use. Are there any out there that will allow me to run a master cylinder and such for the ninja rear hydraulic disc?
- rstnick
Re: KZ400 rearsets
15 Mar 2016 14:34 - 15 Mar 2016 14:35
What does the Ninja 250's look like?
I'm using an '04 GSXR600 set on my KZ650C2.
The brake light switch and master cylinder are attached on the backside of the bracket.
If you can find something similar, and be able to mount it up either on a bracket made and welded to the frame, or if you can drill holes two (or more) mounts into the frame as I did:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 15 Mar 2016 14:35 by rstnick.
- Sims426
Re: KZ400 rearsets
15 Mar 2016 15:00
I'm not sure, I'll look into using the ninja 250 rearsets though, I appreciate the help sir!
- Sims426
- Nebr_Rex
Re: KZ400 rearsets
15 Mar 2016 19:04
Yes. Make sure the peg flips up.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- rstnick
Re: KZ400 rearsets
17 Mar 2016 14:14Sims426 wrote: Also is there clearance issues with the kickstart?
Yes.
I'm able to use the kickstart by raising the footpeg, or removing the clip and pin and taking the peg off.
I use the electric starter 99% of the time. kick is only back up in my case.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Sims426
Re: KZ400 rearsets
25 Mar 2016 09:49
Thanks for all the info guys! Also since the ninja wheel I'm using has a 520 sprocket I'm looking for a 520 16 tooth front sprocket. Are the sprockets interchangeable for the 750 twin and 750 four cylinder bikes? I was also told that the kz750 and 400 twins had the same splines.
- Busabenny
Re: KZ400 rearsets
09 Sep 2019 18:47Sims426 wrote: I'm swapping the stock KZ400 arm for a 2010 ninja 250 swingarm and rear wheel. I've searched around and only people who have made rearsets for drum brake use. Are there any out there that will allow me to run a master cylinder and such for the ninja rear hydraulic disc?
I think this might be an old thread but what did you do for suspension ? The ninja 250 looks like it one takes a solo shock. Thanks
