Air Box Removal
- Little B
Air Box Removal
13 Mar 2016 15:23
Hey Guys.
Been a while but I still have my KZ750. The carbs are headed to Wired George for a rebuild and I got to thinking about taking the airbox out. Thinking of replacing it with Pod filters. Do y'all recommend them or staying with the OEM airbox?
Whats the trick in removing it if I go that route?
1981 KZ750-H2 LTD
- JR
Re: Air Box Removal
13 Mar 2016 16:23
My 750 came with K&N pods and contrary to what some say it was not to difficult to jet. I found an airbox and put it on because I wanted a more stock look . Honestly not a lot of difference in performance between pods and box. Got caught in a rainstorm once when I had pods and the bike coughed and spluttered (wet pods) for 50km and I was lucky to make it home.
Unless you are dead set on the look of pods keep the airbox . New soft supple airbox hoses are a good investment.
The following user(s) said Thank You: Little B
- Olajoe
- Free at last
Re: Air Box Removal
13 Mar 2016 17:07Little B wrote:
Hey Guys.
Word on the street is that's the easiest 5hp move! Coming from down there on eazy street.
Little B wrote: Whats the trick in removing it if I go that route?
milwaukee sazwall, ryobi 4" grinder using the 6" disc, and the sledgeomatic 5lb poi pounder shortshaft handle with a modified long reach cheater. When you end up with more parts taken off then what you started with, it's done.
- Nebr_Rex
Re: Air Box Removal
13 Mar 2016 17:46
If you have the stock exhaust I would keep the airbox, but with new carb and airbox boots.
With a 4/1 I would go with a good set of filters like K&N or Uni.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Re: Air Box Removal
13 Mar 2016 18:23
Welcome aboard. Pods have been beat to death on this forum, so PLEASE SEE:
www.kzrider.com/forum/3-carburetor/60156...eeds-guidance#715004
- Little B
Re: Air Box Removal
13 Mar 2016 18:41JR wrote: My 750 came with K&N pods and contrary to what some say it was not to difficult to jet. I found an airbox and put it on because I wanted a more stock look . Honestly not a lot of difference in performance between pods and box. Got caught in a rainstorm once when I had pods and the bike coughed and spluttered (wet pods) for 50km and I was lucky to make it home.
Not set one way or the other but hated how dificult it was to remove the carbs with it 'in the way'. maybe hoses like you mention is a good idea. I'm not worried about the jetting since wired george will be taking care of it.
@650ed: thanks for the link!
1981 KZ750-H2 LTD
- undiablo
Re: Air Box Removal
14 Mar 2016 11:52
4 into 1 + pods = jetting #35 #70 #140
that the usual wiredgeorge jetting for this combo at sea level.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- bountyhunter
Re: Air Box Removal
14 Mar 2016 17:10Little B wrote: Hey Guys.
Remove the air box. Then, sell your golf clubs, bowling ball, and TV.
You won't have any time for those things, you'll be too busy tuning your bike.
- z1kzonly
Re: Air Box Removal
14 Mar 2016 17:16
[ Do y'all recommend them or staying with the OEM airbox?
Whats the trick in removing it if I go that route?[/quote]
You use a saw zall! Cut it down the middle! on KZ900 - KZ1000's (OUCH)! :ohmy: That's what I did 5 or 6 times in the 70's and 80's till I learned.
That is why they are so hard to come by and so Expensive! OEM's.
This trick goes with all the 4 - 4 pipes stock & ugly I cut in half to make loud! :ohmy:
Re: Air Box Removal
14 Mar 2016 17:23
If I ever decided to remove my airbox I would do it the way the guy in the video below does his.
- car5car
- Banned
Re: Air Box Removal
14 Mar 2016 19:59 - 14 Mar 2016 20:05I would change pods for OEM box.Little B wrote: Hey Guys.
Pods don't filter air good enough. K&N filters are supposed to be oiled and nobody does that. So dust goes thru, killing compression.
There is an article about K&N filters. Do they increase power? yes they do, because air goes thru w/o any cleaning!
So, whoever wants to come and switch my pods to air box, I'll do the work!
www.nicoclub.com/archives/kn-vs-oem-filter.html
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 14 Mar 2016 20:05 by car5car.
- carwash
Re: Air Box Removal
14 Mar 2016 20:31
these guys will make an airbox for you.
www.steeldragonperformance.com/air_boxes_7.html
i've been in touch with them about making one for my KZ550.
There are a few DOHC CB750 guys that claim they work as good or better as a stock airbox, and definitely better than pods. Something about having one pod-type airbox per two carbs, the alternating draw from the carbs creates something similar to the vacuum created by an OEM box.
1980 KZ550A
1980 CB750F
1980 CB750F
