GPZ1100 seat mounting question
- Bozo
- Ride it like u stole it
12 Mar 2016 03:37
I am assembling a GPZ1100 from spare parts I had. My problem is that even with a parts manual I cannot work out what holds/ locks the seat to the frame. The manual pictures don't show what I might be missing.
The frame is from a KZ1000J 1980 model and the seat is from a 1981 GPZ1100 but I assume both frame are alike.
If you have a GPZ1100 laying about can you take some photos please or if you have a picture from a book that would also do.
Picture of the under seat
photo of my project
Close up of the frame where the seat latches
photo of my project
- Nebr_Rex
Re: GPZ1100 seat mounting question
12 Mar 2016 04:29
Latch is on the other side.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Bozo
12 Mar 2016 06:06Nebr_Rex wrote: Latch is on the other side.
I don't have a latch on my frame, have you got a picture of one or can you point me to a picture?. Thanks for your reply.
12 Mar 2016 07:19
Don't those catches go through the blocks and the longer one is the lever?
- OnkelB
12 Mar 2016 08:49 - 12 Mar 2016 08:59
You should have a seat lock on the left side of the frame right next to the top shock mount, looks like this:
To remove the seat you turn the key clockwise to unlock, then pull out the rod that keeps the catches engaged.
Push the catches forward to release them and you can lift the seat off.
To install the seat you slide the front brackets into the holders on the frame, insert the rear catches into the rectangular holes, press down on the back of the seat and push the catches backwards to engage them. Once the catches are engaged you push in the rod to keep them engaged and turn the key ccw to lock.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 12 Mar 2016 08:59 by OnkelB.
- Bozo
12 Mar 2016 14:37 - 12 Mar 2016 14:51
Thankyou ONKELB that is what I wanted, just one more question - does the latch that is attached to the seat (shown in my first picture) have some kind of a spring on it to keep it forward?
As you can see by my photos I mounted the indicator stalks where the latches go, so at the end of the day I might have to make something simpler (I don't really need a lock).
Last edit: 12 Mar 2016 14:51 by Bozo.
- OnkelB
12 Mar 2016 14:54
No spring, it's all manual.
