Checking/Setting Rear Air Shock Pressure?
  • Irish-Kawi
  • Irish-Kawi's Avatar Topic Author
09 Mar 2016 12:55
#714644
So, was reading the FSM for what the correct pressure in the rear shock is and said anywhere from 7.1 psi - 43 psi, but then went on to say NOT to use a tire pressure gauge as it is not accurate and will let air out. It didn't say the right way to check so I am a bit mystified... how do y'all check and set the air pressure in your rear shock for those that have air assisted rear suspension?
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
  • TexasKZ
  • TexasKZ's Avatar
Re: Checking/Setting Rear Air Shock Pressure?
09 Mar 2016 16:13 - 09 Mar 2016 16:21
#714665
A hand pump with a built in guage and a quick release connector rather than screw-on. Bicycle shops carry them.
A little pricey, but likely a quality piece.......
www.progressivesuspension.com/product/1468/mini-gauge-pump
Last edit: 09 Mar 2016 16:21 by TexasKZ.
The following user(s) said Thank You: Irish-Kawi
  • Irish-Kawi
09 Mar 2016 17:00
#714677
Thank you much appreciated :D
