Rear handle is missing?
- car5car
- Banned
06 Mar 2016 19:32
My bike is missing rear handles, attached to top of rear shock. What is right name for that part?
I would like to find it on ebay.
You can see them here:
www.motorcyclespecs.co.za/model/kawasaki...aki_z1000st%2080.htm
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Rear handle is missing?
06 Mar 2016 20:45
Grab rail.
07 Mar 2016 06:51 - 07 Mar 2016 06:53
Kawasaki lists it as a frame grip. aka grab handle, grab bar, etc. Your bike may have had one on the left side only.
From the cross-ref at Partzilla the 1000E frame grip was only used on those 2 models.
I have no idea if a grab bar from a different model would work.
32109-1009 GRIP,FRAME
Last edit: 07 Mar 2016 06:53 by martin_csr.
- MDZ1rider
07 Mar 2016 06:53
I couldn't find a parts list specific to the 80 KZ1000ST, but I'm pretty sure this is what you're looking for. It's an obsolete part from Kawasaki, but reproductions are available.
This Kawasaki 32109-1004 GRIP,FRAME is used on these models and components:
1977 KZ1000-A1 KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1978 KZ1000-A2 KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1978 KZ1000-A2A KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1978 KZ1000-D1 Z1R FRAME-FRAME FITTINGS ('78 D1)
1978 KZ1000-D1 Z1R FRAME-FRAME FITTINGS ('80 D3)
1979 KZ1000-A3 KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1979 KZ1000-A3A KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1980 KZ1000-A4 KZ1000 FRAME-FRAME FITTINGS('79-'80 A3-A3A-A4)
1980 KZ1000-D3 Z1R FRAME-FRAME FITTINGS ('78 D1)
1980 KZ1000-D3 Z1R FRAME-FRAME FITTINGS ('80 D3)
- car5car
- Banned
07 Mar 2016 07:10
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks for your responses.
I ordered aftermarket from ebay, it looks perfect, hopefully bolt holes will match.
- 9er rider
- Keep a cool tool
07 Mar 2016 09:20
diablo or z1E $8.00 each
- car5car
- Banned
07 Mar 2016 12:36What is diablo?9er rider wrote: diablo or z1E $8.00 each
07 Mar 2016 12:47
- mac0239
09 Apr 2023 00:02
Hey "car5car" !, I wouldn't mind a set of these grab rail/ frame grips myself for my ST . Your post is pretty old and last we heard was you were ordering one of the aftermarket ones. Million dollar question though is did it fit your ST? I looked at a bunch of these on Ebay etc and not one says it fits the E1/ST/Shaft model. But no one had measurements either so I could check the hole to hole distance on bike and know for sure if it fits or not. I have a suspicion it fits because why would Kawi have gone to the extra hassle and expense of having to use a different size one for just one model?? The MK11 and the ST are very similar and I would think if t would fir the MK11 it would likely fit the ST? But not willing to gamble on that and order to find out my hunch was wrong.
Green 79' KZ1000st engine-1075 Wiseco kit, k&n pods, dyna ig & coils, and very old Kerker 4 into 1 pipes
Other project- orig Red 79' KZ1000st engine-stock so far with mystery black 4/1 header TBD
- zed1015
09 Apr 2023 01:38Don't think you will get a reply from him.Hey "car5car" !, I wouldn't mind a set of these grab rail/ frame grips myself for my ST . Your post is pretty old and last we heard was you were ordering one of the aftermarket ones. Million dollar question though is did it fit your ST? I looked at a bunch of these on Ebay etc and not one says it fits the E1/ST/Shaft model. But no one had measurements either so I could check the hole to hole distance on bike and know for sure if it fits or not. I have a suspicion it fits because why would Kawi have gone to the extra hassle and expense of having to use a different size one for just one model?? The MK11 and the ST are very similar and I would think if t would fir the MK11 it would likely fit the ST? But not willing to gamble on that and order to find out my hunch was wrong.
Not been on since 2017 and according to his forum status he's banned.
09 Apr 2023 05:30 - 09 Apr 2023 05:31
By mac0239: ... But no one had measurements either so I could check the hole to hole distance on bike and know for sure if it fits or not. ...
Maybe you could measure your 1000 ST, then post the info. so someone here might could do the same to see if they match.
Last edit: 09 Apr 2023 05:31 by martin_csr.
- Wheelhop
09 Apr 2023 05:42
I looked it up on Diablo.com and it was about $12 however, they are out of stock.
I would like to have one of these on one of my bikes but think you would have to remove the rear grab bar in order to install it.
This would make it easier to get bike up on the centerstand.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
