brake line lengths
- gixxerkidd03
brake line lengths
05 Mar 2016 16:18
looking to order some SS brake lines for my KZ,
does anyone know the lengths of;
the rear swing arm line of a '80 kz750e?
and front two lines from a 78 kz 650?
Thanks!
Thanks!
1981 KZ750e
Re: brake line lengths
06 Mar 2016 07:49
The lengths may be listed in the parts diagrams. Kawasaki.com or Partzilla.
For my 81 650-csr the lengths listed are the same as the eye-to-eye measurements.
- daveo
06 Mar 2016 08:30martin_csr wrote: The lengths may be listed in the parts diagrams. Kawasaki.com or Partzilla.
Is "eye-to-eye" the measurement typically used when determining and ordering lengths?
1982 KZ1100-A2/1170 sleeper 😀
- JaFlo
06 Mar 2016 09:09daveo wrote:martin_csr wrote: The lengths may be listed in the parts diagrams. Kawasaki.com or Partzilla.
Stainless hoses are usually measured by the overall length of the assembly, including any fittings that are permanently attached. For example, if you get hoses that have -3AN female fittings on both ends the overall length is measured from the end of each fitting. You then have to account for the length of the banjo fittings to get the correct length for your bike. Some hoses can be ordered with the banjo fitting permanently attached.
- pete greek1
07 Mar 2016 11:26
You can also call some Hose & Equipment places & see if they'll make up some hoses for you
I just rode my bike to a hose & equipment place here in ILL., they measured & made them up while I waited
here's some places in your area
www.google.com/url?sa=t&rct=j&q=&esrc=s&...coj9-8IDKAlTKmrrbmrg
Pete
Pete
