Rear master cylinder help
  • Sardonicus
  • Sardonicus's Avatar Topic Author
20 Feb 2016 06:20
#711596
OK - just so we're on the same page. This is my first bike. Never been on one in my life. Never worked on one but I'm learning. I recently acquired a non running 1976 kz750 twin for $250. Overall things are in surprisingly good shape. Minimal rust - the exhaust down by the mufflers has seen better days but for now I'm concentrating on other things. Waiting on an ignition coil before I can try to make it run so I figured I would get on the brakes. Both brakes locked up tight. I managed to finagle the front master cylinder loose and I'm buying a rebuild kit for it. The rear master cylinder is a whole different flavor of headache - I have a plan for getting the piston out but for the life of me I can't find a rebuild kit for it. Does someone make them and I'm just not seeing it? If not are the parts interchangeable with other models from other years that might be easier to find? Just trying to gauge my options before I go all Macgyver on it.
I took both calipers off and was able to move the piston and spew brake fluid on myself so for the time being I'm operating under the assumption they're fine.
1976 KZ750 B1
  • Rockranch
  • Rockranch's Avatar
Re: Rear master cylinder help
20 Feb 2016 06:45
#711600
Have you tried Z1enterprises.com or partzilla? ......................................Mike
Vroom-vroom!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • Sardonicus
20 Feb 2016 06:53
#711602
Yes I have. Z1 is where I first found the front master cylinder rebuild kit and they do have rear master cylinder kits for 5/8 bore but the kit specifies that it is for a double disc setup. I'm not entirely certain what that means
1976 KZ750 B1
  • Rockranch
20 Feb 2016 06:57
#711603
Sardonicus wrote: Yes I have. Z1 is where I first found the front master cylinder rebuild kit and they do have rear master cylinder kits for 5/8 bore but the kit specifies that it is for a double disc setup. I'm not entirely certain what that means
So the rear MC kit specifies it's for a double disk setup?...hmmm quite odd to say the least.....................Mike
1 modified
  • Sardonicus
20 Feb 2016 06:59
#711606
www.z1enterprises.com/product/KL32-8052 there is also another rear kit that is slightly more expensive but it too says double disc
1976 KZ750 B1
  • Rockranch
20 Feb 2016 07:04
#711609
Sardonicus wrote: www.z1enterprises.com/product/KL32-8052 there is also another rear kit that is slightly more expensive but it too says double disc
You can call them and talk to Jeff. He's a good guy and will help you sort it out..........................................................Mike
1 modified
  • Sardonicus
20 Feb 2016 07:12
#711611
Will do. Thank you for responding.
1976 KZ750 B1
  • pete greek1
  • pete greek1's Avatar
20 Feb 2016 10:14
#711640
The rear master cylinder piston for a 76 KZ 750 twin, part # 43072-004
is used on these models
1976 KZ750-B1 REAR MASTER CYLINDER-BRAKE PEDAL
1976 KZ900-B1 LTD REAR MASTER CYLINDER
1977 KZ1000-A1 KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1977 KZ1000-A1 KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1977 KZ1000-B1 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1977 KZ1000-B1 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1977 KZ750-B2 REAR MASTER CYLINDER-BRAKE PEDAL
1978 KZ1000-A2 KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1978 KZ1000-A2 KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1978 KZ1000-A2A KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1978 KZ1000-A2A KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1978 KZ1000-B2 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1978 KZ1000-B2 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1978 KZ1000-C1 Police 1000 REAR MASTER CYLINDER ('78 C1-C1A)
1978 KZ1000-C1 Police 1000 REAR MASTER CYLINDER (KZ1000-C2)
1978 KZ1000-C1A Police 1000 REAR MASTER CYLINDER ('78 C1-C1A)
1978 KZ1000-C1A Police 1000 REAR MASTER CYLINDER (KZ1000-C2)
1978 KZ1000-D1 Z1R REAR MASTER CYLINDER-BRAKE PEDAL ('78 D1
1978 KZ750-B3 REAR MASTER CYLINDER-BRAKE PEDAL
1979 KZ1000-A3 KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1979 KZ1000-A3 KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1979 KZ1000-A3A KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1979 KZ1000-A3A KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1979 KZ1000-B3 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1979 KZ1000-B3 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1979 KZ1000-C2 Police 1000 REAR MASTER CYLINDER ('78 C1-C1A)
1979 KZ1000-C2 Police 1000 REAR MASTER CYLINDER (KZ1000-C2)
1979 KZ1000-E1 Shaft REAR MASTER CYLINDER (KZ1000-E1)
1979 KZ750-B4 REAR MASTER CYLINDER-BRAKE PEDAL
1980 KZ1000-A4 KZ1000 REAR MASTER CYLINDER(KZ1000-A3-A3A)
1980 KZ1000-A4 KZ1000 REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1980 KZ1000-B4 LTD REAR MASTER CYLINDER-BRAKE PEDAL ('77-'7
1980 KZ1000-B4 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1980 KZ1000-C3 Police 1000 REAR MASTER CYLINDER ('78 C1-C1A)
1980 KZ1000-C3 Police 1000 REAR MASTER CYLINDER (KZ1000-C2)
1980 KZ1000-D3 Z1R REAR MASTER CYLINDER-BRAKE PEDAL ('78 D1
1980 KZ1000-E2 Shaft REAR MASTER CYLINDER (KZ1000-E1)
1981 KZ1000-C4 Police 1000 REAR MASTER CYLINDER ('78 C1-C1A)
1981 KZ1000-C4 Police 1000 REAR MASTER CYLINDER (KZ1000-C2)
Pete
The following user(s) said Thank You: Bowman
  • Sardonicus
20 Feb 2016 10:30
#711641
That is a very helpful list! Thank you
1976 KZ750 B1
  • pete greek1
20 Feb 2016 11:02
#711644
No eBay APP ID and/or Cert ID defined in Kunena configurationMy stock front master cylinder needed to be rebuilt about 10 yrs. ago ,after pricing rebuilt kits for it , it was cheaper for me to buy a new master cylinder from this place, & it still works as good if not better than the stock one
Pete
  • Sardonicus
20 Feb 2016 11:12
#711646
I had found a rebuild kit for $34 but considering the negligible price difference new does seem like a better option. Thank you for that. Do you know of any convenient aftermarket options for a rear master cylinder? Finding something that doesn't need just as much work as mine is proving difficult.
1976 KZ750 B1
  • pete greek1
20 Feb 2016 11:26
#711648
No eBay APP ID and/or Cert ID defined in Kunena configurationdon't know of any after market rear masters , but you can get a complete rebuild kit for yours , here
Pete
