Reverse brake bleed (pump fluid in from bottom)
  • Broken Spoke
  • Broken Spoke's Avatar Topic Author
07 Jul 2006 23:11
#60125
I've drained my front brake for an overhaul and am brainstorming ways to avoid bleeding. Seems to me that slowly pumping brake fluid in from the calipers up toward the M/C would result in less air getting trapped in the system. I'm thinking of trying this on my front brake with a large squeeze bottle and a little plastic hose. Anybody ever try this?:huh:
Post edited by: Broken Spoke, at: 2006/07/08 02:16
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Reverse brake bleed (pump fluid in from bottom)
07 Jul 2006 23:36
#60133
I can't think of any reason that it won't work.
Still sounds like to much effort and time to me.
I used a mighty-vac ($25 at Harbour Freight) to bleed the brakes on all 3 calipers of my ZN700.
Took roughly about 30~40 mins total from start to finish, and the brakes are firm enough that I could probably do a "stoppie" if I wanted to! :woohoo:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
07 Jul 2006 23:40
#60134
What you are proposing is not unheard of. In fact I first heard of it a while back on a dirtbike forum. Try to get your hands on a large syringe to do the job. Suppose to work pretty good.
Get right or get left! <*{{{><
  • gpzrox
  • gpzrox's Avatar
08 Jul 2006 03:35
#60142
I too use the mighty vac. My best friend, however, likes to figure out ways to get the calipers above the master cylinder. Interesting idea, and works for him in practice.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
08 Jul 2006 05:08
#60144
I advocate Russel Speedbleeders.
They make an otherwise arduous task easy and fast.
Of course, they would not work with the "reverse" method , since they are designed to *prevent* backward flow (of air, especially)...
Post edited by: Biquetoast, at: 2006/07/08 08:10
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • kawsakiman
  • kawsakiman's Avatar
08 Jul 2006 15:02
#60278
they make a tool for that. it's called a phoenix injector. i think you can rent one from parts stores. it works great for reverse fluid injection
  • JMKZHI
  • JMKZHI's Avatar
Re: .
08 Jul 2006 21:56 - 03 Dec 2008 18:55
#60351
del
Last edit: 03 Dec 2008 18:55 by JMKZHI.
  • gpzrox
  • gpzrox's Avatar
09 Jul 2006 04:55
#60406
Still thinking about that one, My GPZ has 6 bleed screws in the front, YIPES! Gonna have to take out a loan!
They do work well, though.
  • Wicked_KZ
  • Wicked_KZ's Avatar
10 Jul 2006 03:09
#60662
the easiest way to bleed the brakes is to get a piece of clear tubing and run it into your fluid reservior. All you need to do is keep the tube just under the fluid level and slowly pump the brakes with the bleeder screw open then closing the screw when releasing. You can also just leave the bleeder screw open but it takes a little longer. I have done this several times on several cars and bikes,it always works cuz the bubbles go thru the tube and the air released into the reservoir escapes out of your system. when the bubbles stop you're done and will have a nice firm pedal.
Best part is there is no mess or wasted fluid.
now if you use this method on the front brake be sure to cover your tank so fluid don't get on your paint job... just to be on the safe side.
