KZ250 Front forks - D vs C & W
  • Irish Yobbo
  • Irish Yobbo's Avatar Topic Author
04 Feb 2016 11:44 - 04 Feb 2016 11:59
#709383
I'm looking at getting some replacement forks for my KZ250 W1, but it appear that there are a few different types. On partzilla there are different part numbers for the C & W models compared to the D models. For example, the inner fork tubes:
W1 Inner Fork
D Inner Fork
However, the D and L models share the same outer tubes. The difference here is that the D and L models have an 18 inch wheel, whereas the W model has a 19 inch wheel, and a different outer tube. I presume that means that forks from the D and L models will not fit mine?
Edit: This should really be in the chassis section - how do I move it?
1981 KZ750 LTD
Last edit: 04 Feb 2016 11:59 by Irish Yobbo.
