82 750 n shaft
- Bubbahicks
82 750 n shaft
15 Jan 2016 16:20
Got this old shaft drive with a bad motor, looking to convert it to chain so I can use this 80 1000 engine is have. Anyone know where to start looking for a swing arm that may be compatible ?
- cafebrat
Re: 82 750 n shaft
15 Jan 2016 17:12
Try checking your local craigslist for a parts bike you could use. Maybe check everything your bike will need throughout the build and see if other things can be used too. Or check ebay for a swing arm. Theres a classifieds section on this site you could check to.
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke
81 Honda cm400
- Bubbahicks
- pete greek1
Re: 82 750 n shaft
16 Jan 2016 09:39Bubbahicks wrote: Got this old shaft drive with a bad motor, looking to convert it to chain so I can use this 80 1000 engine is have. Anyone know where to start looking for a swing arm that may be compatible ?
You know that the 80 1000 motor is not just going to swap out into the 750 frame without a lot of fab work to the frame & motor mounts
Pete
The following user(s) said Thank You: Bubbahicks
- Bubbahicks
Re: 82 750 n shaft
16 Jan 2016 14:51
i know it will take some work but once i got something in my head its hard to stop . plus it was my first bike so i cant let it go
- cafebrat
Re: 82 750 n shaft
17 Jan 2016 06:26
Whats wrong with your current 750 motor? Why not just just give it a top end rebuild. I doubt anything lower would go bad.
81 Honda cm400
81 Honda cm400
- Bubbahicks
Re: 82 750 n shaft
18 Jan 2016 02:44
750 motor is roched with 60k on it ,plus where's the fun in that
