550 chain guard
  • rrsmsw9999
  • rrsmsw9999's Avatar Topic Author
550 chain guard
10 Jan 2016 14:40
#706202
Does anyone know if the 550 A/B/C chain guards are interchangeable? I looked at part numbers and they are different, but the I am pretty sure the swing arms are identical, I was looking to put a metal one on. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Nessism
  • Nessism's Avatar
Re: 550 chain guard
10 Jan 2016 16:38 - 10 Jan 2016 16:39
#706224
I'm interested in this topic as well because my bike, a 750E2, uses the same chainguard as the early 550's. As far as I can determine the way the guard mounts on the swingarm is different from many other bikes so not sure about interchangeability.
Last edit: 10 Jan 2016 16:39 by Nessism.
  • martin_csr
  • martin_csr's Avatar
Re: 550 chain guard
11 Jan 2016 02:57 - 11 Jan 2016 03:34
#706255
Not sure, but I don't think they're interchangeable. I could be wrong, but to my eye the mounting bolt holes for the 550C Ltd chain guard seem to be more far forward than the 550A. You should be able to make a better guess than I can, though, since you can put a tape measure on the 550A stuff. Also, please note that the swing arm part numbers are different, so I don't assume they're the same. :)
Last edit: 11 Jan 2016 03:34 by martin_csr.
