KZ1000A1 production data?
- Mk.2
02 Jan 2016 12:14
I'm searching for monthly production by VIN if it even exists, if anyone has a link or know of a database that I could use please advise.
I've got two Kz1000A1's that I would like to have a new VIN label made for and they both have had their frames refinished already with their original VIN labels destroyed prior to my ownership.
I'm trying to determine the approx. build date by month, Don't know if I should list the VIN's here but can PM them if anyone could find the answer I'm looking for.
thank you
thank you
Matt
KZ1000A1--current project
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
- Mk.2
Re: KZ1000A1 production data?
16 Jan 2016 07:19 - 16 Jan 2016 07:22
apparently this info doesn't exist in the detail needed to find what month my bike was actually produced.
Does anyone know what month/year Kaw started production on the next model year ? example, did they start production of 1977A1 in October of 1976?? if I knew what month production began I could take the known output for a given year as according to the VIN range for that model and do a little division to narrow down what could of been the monthly production.
this would be a guesstimate but possibly in the ballpark.
OR
If any 1977 KZ1000 owners who still have their original VIN stickers would care to compare my VIN's to yours if close please let me know what your build month/year was. I know it's asking alot, thank you for your efforts to help me out.
I think at some point it wouldn't be a bad idea to start a VIN database not only for this very reason but to list our classic bikes especially if you have a model that is deemed more rare than others, like the Shelby registry for example.
Here are my two VIN's for my 1977 Kz1000A's, if yours happens to be close, please share what your build date info is either here or PM me for privacy concerns.
KZT00A-0069XX
KZT00A-0072XX
OR
KZT00A-0069XX
KZT00A-0072XX
Matt
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
Last edit: 16 Jan 2016 07:22 by Mk.2.
- spdygon
16 Jan 2016 16:24
My has a date of 11-76
Frame # -502810
Engine #- 009737
Wow way off...just notice that .lol
Frame # -502810
Engine #- 009737
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
The following user(s) said Thank You: Mk.2
- pete greek1
17 Jan 2016 09:44
I don't know if this helps,
Kawasaki Part Cross Reference Software contains information for this bike.
Year & Model '77 KZ1000-A1
Color(s) (1) Diamond Wine Red
(2) Diamond Sky Blue
Frame No. Range (Japan MFR)
KZTOOA000101 - 026623
(USA MFR)
KZTOOA500001 - 507026
Engine No. Range KZTOOAE000101 - 41170
Engine No. Location RH top crankcase, below carburetor
Cylinder Mark 1.015L
Cylinder Mark Location Front RH corner
Engine Type 4-stroke, 4-cylinder, DOHC, Air cooled
Bore X Stroke 70.0 X 66.0 mm
Compression Ratio 8.7:1
Maximum HP 83 at 8000 rpm
Maximum Torque 8.1 kg-m at 6500 rpm
(USA MFR)
- Mk.2
17 Jan 2016 11:54
Thanks for posting fellas, Spdygon your bike was USA made, made alot less here vs Japan built like mine. Cool
Keep EM coming A1 owners!
Matt
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
- bluej58
18 Jan 2016 03:16
I have an early A1 frame in the basement, I'll look at the sticker tonight
78 KZ1000 A2A
- bluej58
18 Jan 2016 14:29
I don't know what the problem is with giving out vin #'s
But here it is and I think it 'is right in the middle of your ball park
78 KZ1000 A2A
- Mk.2
18 Jan 2016 16:11
Thanks for sharing Blue, right in the middle of my two, wonder if any other members have a 9/76 or earlier build date? Hopefully they will share also.
Matt
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
- missionkz
18 Jan 2016 22:07 - 18 Jan 2016 22:13
Mine is also 10-76 and the VIN is
KZ100A-006828
I picked the bike up from the dealership in February 1977.
KZ100A-006828
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 18 Jan 2016 22:13 by missionkz.
- Mk.2
19 Jan 2016 15:15
Bruce thanks so much for posting, It confirmed mostly that both of mine were likely built 10/76 like yours and another contributer above.
If anyone else has an earlier build date please include it here, I'm curious what month Kaw began production began, I'm gonna email Jim at Redline Cycle as they have I believe the first 1977 a1 produced, it was a magazine test bike.
Matt
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
- missionkz
19 Jan 2016 16:06
Not that it makes any difference, but my engine case stamping is:
KZT00AE011094
KZT00AE011094
Bruce
1977 KZ1000A1
1977 KZ1000A1
- starfire
21 Jan 2016 07:57
Hi. I want to replace my missing headstock decal so I'm trying to determine the month of production. KZT00A25200. I know it's right at the end of the 1977 production run. Any help appreciated!
