'82 GPZ1100 front disc brakes
  • yorkieUK
  • yorkieUK's Avatar Topic Author
29 Dec 2015 07:16 - 29 Dec 2015 07:21
#704737
Hi guys.
I bought an '82 GPZ1100 plunger chop a few months ago to accompany my KZ1000P-9.
I use the KZP for touring & the GPZ for short rides.
The front discs are due for changing on the GPZ and I was wondering if anyone could suggest a good upgrade to the standard discs that are on it?
The current 260mm discs seem to be tiny for the output of the bike.
Attachment WP_20151214_010.jpg not found
Attachment WP_20151214_008.jpg not found
Attachment WP_20151214_003.jpg not found
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
Last edit: 29 Dec 2015 07:21 by yorkieUK. Reason: Add photo
  • redhawk4
  • redhawk4's Avatar
Re: '82 GPZ1100 front disc brakes
29 Dec 2015 07:27 - 29 Dec 2015 07:36
#704741
The 260mm discs were used on a lot of Kawasaki bikes at that time, I don't recall the brakes being poor back when those bikes were new but things have moved on a lot since the early 80's. They were certainly more effective than the larger rotor set up (295mm) that was on the earlier bikes, they have more pad area and run better pads. They do look small compared to modern bikes that have really gone towards huge diameters on their brakes rotors. I actually have the same disc on the rear of my 78 KZ1000A with a Police wheel, it came from a GPz750 parts bike I had. There are plenty of those rotors for sale and I think EBC does a replacement rotor if you want new ones, but they are expensive, If you are thinking of going to a larger rotor then you encounter problems of how to mount your calipers on the fork legs. It really depends on what you are trying to achieve, but unless you are planning on some very tough braking requirements I would have thought replacing those discs with a serviceable set, with quality pads and braided hoses would give you plenty of stopping power given the type of bike you have. Given some of the mods you see on the forum the sky is the limit in terms of what can be done, it's just a case of whether it's worth it.
Some of the Vulcan cruiser bikes use the same 7 bolt mount for the rotor to the wheel, They are about 300mm on some of the models, so there are possible swaps to a bigger rotor etc. from Kawasaki parts, but I don't know what fork diameters they use or what else could be swapped over to use the Vulcan calipers or you existing ones.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 29 Dec 2015 07:36 by redhawk4.
The following user(s) said Thank You: yorkieUK
  • yorkieUK
29 Dec 2015 07:37 - 29 Dec 2015 07:42
#704744
The ebay item id given is invalid, no result has been sentThanks redhawk4.
She does brake okay, I was just putting the feelers out to see if there had been an successful upgrades done by anyone on the forum. I'd like to put a set of wavy discs on but I can only find cheap Chinese ones on eBay and don't trust their quality at all.
Last edit: 29 Dec 2015 07:42 by yorkieUK. Reason: add link
  • PLUMMEN
  • PLUMMEN's Avatar
29 Dec 2015 08:16
#704751
Can you lock up the front wheel with the current brakes? ;)
  • yorkieUK
29 Dec 2015 08:22 - 29 Dec 2015 08:23
#704752
Not been in the situation where I've shit myself yet. One day someone will pull a car out in front of me, but not yet ;)
Last edit: 29 Dec 2015 08:23 by yorkieUK.
  • Nebr_Rex
  • Nebr_Rex's Avatar
29 Dec 2015 08:48
#704756
What GPz?.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • TexasKZ
  • TexasKZ's Avatar
29 Dec 2015 09:04
#704763
Nebr_Rex wrote: What GPz?.
OPSays 82 GPz 1100
  • PLUMMEN
  • PLUMMEN's Avatar
29 Dec 2015 09:57
#704768
yorkieUK wrote: Not been in the situation where I've shit myself yet. One day someone will pull a car out in front of me, but not yet ;)
Thats my point if you have enough brakes already to lock the wheel up Id look into better rubber that can hold the road better. ;)
  • yorkieUK
29 Dec 2015 10:01
#704769
You seem to be of the assumption that my brakes aren't working? They are.
I'm just asking if anyone has found an upgrade to the originals before I replace my worn discs!
  • Nebr_Rex
  • Nebr_Rex's Avatar
29 Dec 2015 12:48
#704798
The only things that I see as GPz are the front wheel, fender
and maybe the engine. When new The GPz's had more than enough brake.
Run her up to 90kph and squeeze that lever and check it out for your self.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
29 Dec 2015 13:16 - 29 Dec 2015 13:16
#704803
[quote="yorkieUK" post=704769
...................I'm just asking if anyone has found an upgrade to the originals before I replace my worn discs![/quote]
No need to replace the rotors (disks) unless they have severe damage. You can have them properly resurfaced for less than the cost of replacements. Ed
See:
www.truedisk.net/
Last edit: 29 Dec 2015 13:16 by 650ed.
  • Nebr_Rex
  • Nebr_Rex's Avatar
29 Dec 2015 13:54
#704809
Try a Spares Unlimited dealer.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
