Z1r owners ?
- spdygon
Z1r owners ?
09 Dec 2015 16:14
Friend of mine needs a rear master cylinder for his z1r. I look at it and the inside of the bore is pitted.
I know that one from a 77-78 kz1000a wont fit because I have one and does not bolt up.
My question is...Will another year model or is there one that can be fitted .
He just got it running but has no rear brakes
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- pete greek1
Re: Z1r owners ?
10 Dec 2015 08:42
Is it a 78 or an 80 Z1R?
Pete
Pete
- pete greek1
Re: Z1r owners ?
10 Dec 2015 08:59 - 10 Dec 2015 09:10
The part # for a 1978 Z1R rear master cylinder assembly is 43015-1047 is used on all these models according to Partzilla
1977 KZ1000-A1 KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1977 KZ1000-B1 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1978 KZ1000-A2 KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1978 KZ1000-A2A KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1978 KZ1000-B2 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1978 KZ1000-D1 Z1R REAR MASTER CYLINDER ('80 D3)
1979 KZ1000-A3 KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1979 KZ1000-A3A KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1979 KZ1000-B3 KZ1000 LTD REAR MASTER CYLINDER-BRAKE PEDAL (KZ1000
1979 KZ1000-E1 Shaft REAR MASTER CYLINDER (KZ1000-E2)
1980 KZ1000-A4 KZ1000 REAR MASTER CYLINDER(KZ1000-A4)
1980 KZ1000-D3 Z1R REAR MASTER CYLINDER ('80 D3)
1980 KZ1000-E2 Shaft REAR MASTER CYLINDER (KZ1000-E2)
Pete
Pete
Last edit: 10 Dec 2015 09:10 by pete greek1.
- pete greek1
Re: Z1r owners ?
10 Dec 2015 09:18
Sorry I just noticed some of the years & models are for the brake pedal
but you'll see which years & models use the same master cylinder
Pete
Pete
- spdygon
Re: Z1r owners ?
10 Dec 2015 14:17
78 model ...I have a master of my 77 kz1000a and it does not work. The way the master is molded is different.
1974 Z1 900 project
1974 Z1 900 project
- pete greek1
Re: Z1r owners ?
10 Dec 2015 14:31
Is it from an A2 ?, It only shows for 78 models A2 or A4
Pete
Pete
- Barry2
Re: Z1r owners ?
10 Dec 2015 20:50
www.zedder.com
has a lot of interchange info on motorcycle parts, for future reference.
1976 KZ900
