750 Twin B3 Wheels upgrade
Re: 750 Twin B3 Wheels upgrade
09 Dec 2015 13:04
" What would the advantage be for the direct bolt sprocket to hub?"
Except for the elimination of the very slight (unnoticeable) slack when pulling away from a dead stop I can think of no advantage of eliminating the cush drive.
However - the DISadvantage is that there will be more stress on the engine/transmission components when going from neutral to first gear. That little bit of "clunk" the first time (maybe more than once) when you click the cold tranny/clutch in gear when going riding can put stress on parts, but the cush drive tends to soften the impact somewhat since it has a bit of "give". I haven't read of that clunk damaging a KZ engine / tranny, but on my old BSA that had no cush it ended up literally breaking the engine case into two pieces. That made for a very bad night and a number of long days to follow.
- 80B4
09 Dec 2015 17:15
Those wheels are rare and collectable. The rear is lighter than a Kawasaki wheel.
There may be additional stress on the transmission parts but any problems may take years and tens of thousands of miles to develop.
If you keep the chain tension adjusted correctly and you keep it lubed you should be fine.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- Timbox
09 Dec 2015 17:27
I thought it was worth fixing even if I plan on going to the KZ1000 LTD rear wheel. I have never seen a street bike with a non cush rear wheel before.
Long time shade tree wrencher
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
- pete greek1
10 Dec 2015 08:37
An identification mark of a Morris Mag is an M with a circle around the M stamped on either side of the air valve, I have them on my 76 LTD 900, which I believe was the only year & model that came with Morris wheels stock, in stead if the Enkie's or Kawasaki mags
Pete
Pete
- Timbox
10 Dec 2015 12:57
Thanks for clearing that up, Found the marks today both front and back on this bike has the "M" by the valve stem. I think I will keep the front, add another disk and caliper. For the rear I really think I will go with a wheel that has a cush in it.
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
- z1kzonly
10 Dec 2015 13:10
EBay will be your friend, if you want to get rid of the Morris Mag Wheel. Just Sayin' As long as you have no love affair with any of the forum members. To offer them up to them 1st.
- pete greek1
10 Dec 2015 14:36
You never let me know if you have a 16 inch rear, because I have a 16 inch rear drum brake Henry Abe mag that you might be interested in
Pete
Pete
- Timbox
11 Dec 2015 03:16
Yes I have a 16 rear wheel but I want to stay with a disk brake. Thanks
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
- Timbox
Re: Just wanted to add a pic of the "M"
12 Dec 2015 11:53
Here is the pic from the rear wheel.
Attachment WheelID.jpg not found
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
