Axle and pivot shaft spacers
  • johnnymoff
  • johnnymoff's Avatar Topic Author
22 Nov 2015 19:59
#700058
how to people make (or get) spacers for swingarm swaps?
Engine: 77 KZ1000 A1
Frame: 78 KZ1000 B2
Carb Type: VM 26 with accelerator pump.
Needle clip: 3rd (middle) position
Pod air filters
Main Jet 132.5
Idle Jet 20
Clip position on needle 3rd (middle)
Exhaust 4 into 1 Vance and Hines
PO says 1170 kit installed.
  • TexasKZ
  • TexasKZ's Avatar
Re: Axle and pivot shaft spacers
23 Nov 2015 03:15
#700075
Sometimes a couple of ordinary flat washers from the hardware store wmill do. If there is a fairly large gap, custom spacers look better, so a machine shop will need to be involved.
  • floivanus
  • floivanus's Avatar
23 Nov 2015 04:12
#700079
I did the wheel spacers, and swingarm pivot bushing for my zx6 swingarm swap on my bike; but your question is pretty open ended there killer. What swingarm are you looking to swap to?
Past; 78 kz1000, 83 kz550
Andrew
  • johnnymoff
23 Nov 2015 06:08
#700097
I have washers now (see pics). I am using the washers just to figure out how big the spacers need to be. I have not finalized the exact spacing yet, But when I do, I will want to replace the washers with something that looks nicer. I still need to work at getting the wheel in the center of the bike and in the center of the swingarm.
I bought this bike with a GS arm and a custom or aftermarket brake caliper mount. Because I don't have a stock caliper mount (bracket), I can't follow exactly what other people have done spacer-wise for this swap. The caliper is a performance machine - I think the mount might have come form there too - but I don't know for sure.
For some reason, the person who put the arm on put two washers on the right side of the pivot shaft and none on the left. I am going to experiment with moving the arm over to the right a little - there seems to be room and I have seen others' posts that had one spacer on either side. img_2977.jpg shows the pivot shaft spacers on the right near the brake linkage.
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
  • baldy110
  • baldy110's Avatar
23 Nov 2015 08:32
#700118
I am lucky enough o have a lathe in my shop. I take old spacers and turn them down to what I need.
[IMG
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Nov 2015 10:09
#700126
i pm'd ya.
the two washers should be on either side of the swingarm pivot.
your on the right track getting the back ones figured out.
