Tank sealer products?
- rrsmsw9999
16 Nov 2015 19:57
Hi all. So my acid and prep went well, but it turns out the old tank has a couple pinhole leaks now. What have you used to seal and what works? R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- bountyhunter
Re: Tank sealer products?
16 Nov 2015 21:33 - 16 Nov 2015 21:35
I sealed my tank with Kreem 30 years ago and it has held up well. I used the whole bottle and it made a thick inside coating.
www.motorcycle-superstore.com/7407/i/kre...device=c&matchtype=e
Last edit: 16 Nov 2015 21:35 by bountyhunter.
- Kidkawie
- I bleed premix
17 Nov 2015 00:58
If you plan on repainting have the holes welded.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
17 Nov 2015 03:16 - 17 Nov 2015 03:18
For a tank that's rusted through, I'd use a premium tank sealant such as KBS or something from Eastwood or West Marine.
In a topic which I can't find, jeff.saunders said he used west system epoxy to repair a tank that was in really bad shape to give it some structural integrity. Below is a different reply about the stuff.
West Marine --- West System epoxyBy Jeff.Saunders: What I've used on tanks that you can't seal using Kreem or Por15 is an marine epoxy resin to line the tank. West system marine resin epoxy. 105 resin and 205 hardener
This mix creates a hard shell inside the tank that's impervious to gasoline. Use a 5:1 mix.
Last edit: 17 Nov 2015 03:18 by martin_csr.
17 Nov 2015 03:26
I've used Caswell's Epoxy tank sealer on a couple tanks and it's good stuff. Really thick and reinforces the metal for those tanks with holes and/or thin metal. If there are holes there may be others close behind.
Por-15 tank sealer is thinner and easier to use. If flows better so you can be assured the entire tank is coated on the inside easier than with Caswell's, which is thick as honey. If using Caswell's I recommend thinning it per the directions on the package.
- jackleberry
17 Nov 2015 07:01
Thinking outside the box a bit, you could also whack that spot with a ball-peen hammer, and then Bondo in the dent you've created for an out-side-the-tank solution. Assuming of course that there's only one hole and that it's substantial.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- floivanus
17 Nov 2015 08:00
Bondo wouldn't hold up to gas. If you need to do something, drill the pinhole out slightly (to clean the hole) flux and braze or solder the pinhole, then seal if you must
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Topper
17 Nov 2015 08:27
I tried using RedKote tank liner on a bike once. I followed the instructions to the letter and it still leaked. Can't recommend taht product.
www.amazon.com/Red-Kote-Quart-Sealer-Diesel/dp/B009X0JOSM
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
17 Nov 2015 08:50
I wouldn't depend completely on any kit. Maybe the tank needed more prep than specified in the instructions. ???
Preparation is key. I would clean the tank & treat the rust before using anything from a kit. The kit preparations & pre-treatments would be redundant steps.
I sealed a fuel tank with Kreem & it worked perfectly. Before using the kit, I did some extra work to make darn sure there was no rust or dried up fuel in there. It's been a while, but I think I used ss nuts & MEK --- the nuts for the rust & the solvent to dissolve any petroleum residue. I wanted the metal as clean & bare as possible before using the kit. Then I followed the Kreem instructions exactly.
- rrsmsw9999
18 Nov 2015 08:33
Yep will do another flah with denatured alcohol for the gas and then power was and full dry with a heat gun, then coat. Will use KBS gold standard coating. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
