530 chain conversion
- JaFlo
12 Nov 2015 11:06
I'm about to order 530 sprockets and a chain for my 82 kz750ltd. If my math is correct, a 16 front sprocket and a 38 rear sprocket should put me close to stock gearing (based on stock 13/32 630 sprockets). The stock 630 chain is 84 links, so that puts me at 102 links for a 530, correct?
Re: 530 chain conversion
12 Nov 2015 11:41JaFlo wrote: I'm about to order 530 sprockets and a chain for my 82 kz750ltd. If my math is correct, a 16 front sprocket and a 38 rear sprocket should put me close to stock gearing (based on stock 13/32 630 sprockets). The stock 630 chain is 84 links, so that puts me at 102 links for a 530, correct?
Sounds right.
- JaFlo
12 Nov 2015 12:42
If I plan on going to an 18" rear wheel, should I go with a 40 tooth rear sprocket?
- zukdave
12 Nov 2015 14:04
On the street I run 16-42 with 530 chain.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
