Brake Caliper Rebuild
- Bowman
28 Oct 2015 07:53
Anybody know just how clean the piston and cylinder have to be to be still usable? Here's some pics of where they are at now. It's off a 76 KZ750 twin in case that matters.
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
Re: Brake Caliper Rebuild
28 Oct 2015 13:18
That piston is junk. Get a new one.
The caliper has some pretty deep corrosion. I'd try scraping out the groove with a plastic/wood scraper, followed by scrubbing with scotchbrite. A stainless steel brush on a dremel would be a good option if you have one. Can't tell for sure but if the pitting is too deep you may have to look for some new calipers. Oh, and make sure to use OEM Kawasaki seals. K&L brand caliper seals are JUNK. Very hit and miss. I've been burned before and wouldn't use them unless you have no choice.
The following user(s) said Thank You: Bowman
- Bowman
28 Oct 2015 14:18
Thanks Nessism. I feared that would be the response. The good news is that it is the rear brake which is really only there to give your right foot something to do right?
Now to try and find 40 year old caliper bits that are not in even worse shape.
- floivanus
28 Oct 2015 15:05
Post up a pic of the whole caliper, if I have one it's your's for shipping cost.
Same for if you just need a piston
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Bowman
28 Oct 2015 16:16
Here ya go. Much appreciated.
- floivanus
28 Oct 2015 20:43
Just home, I'll see what the inside looks like tomorrow
Attachment image-23.jpg not found
Andrew
Andrew
- redhawk4
29 Oct 2015 03:27 - 29 Oct 2015 03:29
The actual caliper looks like the same one used on the front of many Kawasaki's from 1978-1980 so it should be easy enough to find something in working order.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 29 Oct 2015 03:29 by redhawk4.
- floivanus
29 Oct 2015 05:43
I believe the piston sizes are different between the fronts and the rear, not certain tho, I swapped mine out.
Andrew
Andrew
- floivanus
29 Oct 2015 06:03 - 29 Oct 2015 06:05
Piston wiped off one little rust spot on main body, pin head sized, one rust spost at bottom (not near where the seal would be) and looks like plier marks at the top. caliper bore should be good but has old dry brake fluid in it. Let me know
Attachment image-24.jpg not found
Attachment image-25.jpg not found
Attachment image-26.jpg not found
Andrew
Andrew
Last edit: 29 Oct 2015 06:05 by floivanus.
- Bowman
29 Oct 2015 09:09
Sent you a PM
