Is the KZ650 18" Rear Alloy the same as on KZ1000?
  • redhawk4
  • redhawk4's Avatar Topic Author
19 Oct 2015 07:26
#695196
I've heard the bearings are different sizes and can be changed, but is the casting basically the same for 78 models, or similar, with the 4 bolt rotor?
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • baldy110
  • baldy110's Avatar
Re: Is the KZ650 18" Rear Alloy the same as on KZ1000?
19 Oct 2015 07:37 - 19 Oct 2015 07:39
#695197
Yes, the 650 version has smaller bearings but those can be swapped out if needed. You still need the spacers for whatever bike the wheel is going on though as they are also different.
Last edit: 19 Oct 2015 07:39 by baldy110.
The following user(s) said Thank You: PLUMMEN, redhawk4
  • redhawk4
19 Oct 2015 08:04
#695199
So if the KZ1000 already has an alloy rim you would already have the correct spacers?
1977 KZ650B1
1980 Suzuki SP400
  • baldy110
  • baldy110's Avatar
19 Oct 2015 11:51
#695230
Yes it should but if you already have the rim why are you trying to swap in another one.
  • redhawk4
19 Oct 2015 16:19
#695271
Going to an 18" rim on the rear - plus the wheels I have are Lester Mags so I plan on changing them both as I don't imagine ever paying the prices being asked for an 18" Lester Mag. I bought a front wheel today and am still deciding whether to go ahead putting my 18" Police rim on the rear, which benefits from being tubeless and 2.5" wide, but means I have to change the brake caliper for the different rotor or whether to pick up a KZ650 wheel that's for sale locally which has the right rotor fitment etc. but is only be a 2,15 rim.
1977 KZ650B1
1980 Suzuki SP400
  • baldy110
  • baldy110's Avatar
21 Oct 2015 13:21 - 21 Oct 2015 13:22
#695350
They are all 2.15" rims, the only one that was different were the KZ1000Rand KZ1000P, they came with 2.50" rims
Last edit: 21 Oct 2015 13:22 by baldy110.
  • PLUMMEN
  • PLUMMEN's Avatar
21 Oct 2015 13:35
#695353
Id try and get the other wheel complete with all the spacers so you can trial fit everything and make sure the wheel is centered and caliper isnt in a bind. ;)
  • redhawk4
21 Oct 2015 18:42
#695414
At the moment I have a 1988 Police Wheel which is the 2.5" width. I think this is better suited to a 120 tire. It looks, and from rough measurements, to be the same width as the current rear with regards to the spindle, I will trial fit it here in the next day or so. Biggest issue so far is the rotor it's the 7 bolt type not the 4 bolt I have two front GPz 750 rotors that bolt up to the wheel but they are 260mm diameter. I have not been able to find a rotor with the diameter of the original and a 7 bolt mount. The GPz550 has a 260mm rear rotor, if the parts diagrams are to be believed,, I bought a GPz rear caliper off ebay, I'm going to see if it will fit, but suspect the diameter of the hole may be too small for the spindle and wonder if it will be the same width as the KZ1000 one from a spacing point of view on the spindle.. Given all the complications, I'm wondering about getting a KZ650c rear wheel, which seem fairly common. that would accept my existing rotor.
1977 KZ650B1
1980 Suzuki SP400
