bike identification, what do i got here?
- tylerstedham
18 Oct 2015 06:19
Just baught it, seems to be a kz650 with a 750 engine, help confirming what she is please!
- loudhvx
Re: bike identification, what do i got here?
18 Oct 2015 17:43
650B with 750 motor
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Kidkawie
- I bleed premix
19 Oct 2015 03:45
Is this a trick question? lol Kawasaki pretty much spells it out for you.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
19 Oct 2015 03:52 - 19 Oct 2015 04:34
He isn't sure exactly which KZ650 it is & what 750 model the engine is from. From his other topic, the bike is probably a 77 B1 & the engine should be from a 1980 750 Ltd, but it has the engine covers from the 650. The points ignition & generator may have been swapped from the 650. ??? For most stuff it's handy to know exactly what you're working with.
Last edit: 19 Oct 2015 04:34 by martin_csr.
- JR
19 Oct 2015 06:56martin_csr wrote: He isn't sure exactly which KZ650 it is & what 750 model the engine is from. From his other topic, the bike is probably a 77 B1 & the engine should be from a 1980 750 Ltd, but it has the engine covers from the 650. The points ignition & generator may have been swapped from the 650. ??? For most stuff it's handy to know exactly what you're working with.
Carbs are probably also from a 650. Not 750 carbs for sure.
- loudhvx
19 Oct 2015 07:11 - 19 Oct 2015 07:17
The 650, if it was a 77, would have had the excited-field type alternator. That would have required the alternator cover with the three screws. If it has the three screws, then he has the 650 charging system.
EDIT: I checked out the other thread... so yes, it's a 77 650 B1 (made in 1976) with a 750 motor apparently using the 77 650 charging system.
www.kzrider.com/media/kunena/attachments.../20151018_082140.jpg
Thread:
www.kzrider.com/forum/3-carburetor/60010...0-engine-carb-tuning
Thread:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 19 Oct 2015 07:17 by loudhvx.
