looking to lower my kz
- lilpeaty
28 Sep 2015 09:21
Is the best way to lower the bike just to get some smaller shocks and shorter forks? the bike is just a little too tall for me at the minute and i need to drop it about two inches.
- Kidkawie
- I bleed premix
Re: looking to lower my kz
28 Sep 2015 10:42
You can buy or mod your seat.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- lilpeaty
28 Sep 2015 11:16
i like the seat being as cush as it is, so would i have to get new forks as well as new shocks or just the shocks?
28 Sep 2015 11:21
shorter shocks and raise the fork legs in the triples.
- racer54
28 Sep 2015 12:35
I use shorter shocks. Measure what you have so you know where to start. Other bike model shocks bolt on but I personally dont know which ones they are. Some have used Harley shocks and I thennk shocks off of a Kawasaki Vulcan are supposed to work but take into consideration weight of bike. A harley shock may fit but it may be a little stiff from wieght difference of bikes. There are shock lowering brackets out there that some use but there are various opeinions on them. You can raise forks up through trees for sure. I have H2 forks on mine. They are about 2" shorter. Or you can dissasemble your forks and put a spacer inside(make or buy them in various lengths-usually 1"-2"-3") to shorten forks.
