Deglazing brake rotors...
- savedrider
- 1975 Z1-B 900
07 Jul 2006 11:38
Any problem using 80 grit crocus paper to deglaze the front brake rotors when I change the pads? I do this as normal procedure on all my trucks, just want to make sure there is no snaffoo in doing it on these rotors.
Thanks
Thanks
Get right or get left! <*{{{><
- wireman
- savedrider
- 1975 Z1-B 900
Re: Deglazing brake rotors...
07 Jul 2006 12:38
Brake cleaner is fine for a final wash, but a quick circular honing with heavy grit sandpaper usually helps to seat the new pads better.
- fixer5000
08 Jul 2006 00:42
savedrider wrote:
i did it...after ill guess 500 miles pads seem to be seating fine...steve
Thanks
1978 kz650b pretty much stock
massachusetts
massachusetts
