Kz550 Handlebar Replacement
- nickleo373
25 Sep 2015 16:46
Hey everyone
I'd like to replace the big LTD handlebars with something a little bit lower. Ideally I'd like to get Pro Taper or Renthal dirtbike bars. I attempted to switch them out last winter with a set of 7/8 pro tapers, however the kz550 handlebar electronics wouldn't slide over the new bars. Can anyone point me in the right direction on which bars I can use while keeping the stock handlebar electronics?
1981 KZ550C LTD
"If you ain't first, you're last"
- missionkz
Re: Kz550 Handlebar Replacement
25 Sep 2015 17:05
Except for cable length and where the front wheel master cylinder sits in the bend, in front of the grips, I can't hink of any reason any 7/8" bars would not work. The cross bar has to go of course.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
