1981 KZ750H Fork Oil Capacity
  • dpehrson
  • dpehrson's Avatar Topic Author
20 Sep 2015 23:55
#691108
Cheers,
I completely disassembled, cleaned, replaced the seals and reassembled the front forks of my '81 KZ750H. Unfortunately, I have not been able to locate someone locally with a shop manual or the experience in refilling the forks with oil. Will someone please lend a hand in providing me with the proper process and capacity of refilling the forks with oil.
Thank you kindly,
PS... I also own a 1978 KZ1000-D1 Z1R and a 2000 KZ1000-P19 Police which I need the same info on for winter projects... if anybody has front fork capacities for these bikes, I would be equally thankful. Dave.
Re: 1981 KZ750H Fork Oil Capacity
21 Sep 2015 02:02
#691117
From the manual:
Attachment 00003a-108.jpg not found
The following user(s) said Thank You: dpehrson
  • martin_csr
  • martin_csr's Avatar
21 Sep 2015 02:30
#691118
Here's a site w a pdf manual & wiring diagrams. mbsween. bike-night. KZ750L3 page
Scroll down & click "The Bible" link. .................. search tags mbsween KZ750L3.
Note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
  • dpehrson
21 Sep 2015 18:19
#691270
650ed, Thanks a million!!!
  • dpehrson
21 Sep 2015 18:21
#691271
Martin_csr, Thanks a million!!!
  • martin_csr
22 Sep 2015 03:09 - 22 Sep 2015 03:18
#691297
I would go ahead & get a factory manual off of eebbaayy or something. The pdf is poorly scanned ---- the bottom is lopped off of some of the pages, so some info is missing. Kawasaki manuals have a model application chart on the back cover, so make sure your 81 750-H2 is on the list. There are several pretty cheap on eebbaayy right now. $25-30T (yellow cover).
search = KZ750 manual
Last edit: 22 Sep 2015 03:18 by martin_csr.
  • dpehrson
26 Sep 2015 18:32
#692082
Ed, thanks a million. The 750 is back on the road better than before.
