Front caliper brackets
- hunter_jbh2
15 Sep 2015 21:39
Need to know where I can find new inserts for where the bolts that go through the caliper bracket and mounts the caliper to the bracket. 78 KZ650 C
Re: Front caliper brackets
16 Sep 2015 03:02 - 16 Sep 2015 03:04
Which parts on chart below? Ed
Attachment 00003c-15.jpg not found
Attachment 00003b-32.jpg not found
Last edit: 16 Sep 2015 03:04 by 650ed.
- hunter_jbh2
17 Sep 2015 04:15
Hi Ed, there is not a part number for what I'm talking about. But the part I'm looking for is what #11 and #12 go on to.
17 Sep 2015 04:42
I may be wrong, but if you're talking about the inserts circled in red in the diagram below, I don't think you can buy them separately. I suspect you will need to buy the bracket they are mounted into. Ed
Attachment 00003b-33.jpg not found
The following user(s) said Thank You: hunter_jbh2
- MDZ1rider
17 Sep 2015 07:02
Also be aware that those brackets, at least on the 900's, are different from side to side. There is a left and a right.
- hunter_jbh2
23 Sep 2015 22:21
Those were the parts I was looking for. I ended up modifying them to make them work. The ends on a couple of them were a bit smashed. Thanks for the help.
