z500 front end cable routing
- razmo99
14 Sep 2015 14:22
I have recently been working on my bike and have noticed that the cable routing at the front end of the bike for the headlight. handlebar controls and throttle cable looks a bit off. I have looked through the FSM and it doesnt really have any good shots of how the cables should be routes and any pictures that show it arnt that clear. I was wondering if anyone know the OEM way that the cables are meant to be routed.
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
- Tyrell Corp
Re: z500 front end cable routing
15 Sep 2015 04:09
If you look on the frame just behind the headstock there are a 3 holes that hold a clutch cable clip, quite a rare part that usually goes missing. Throttle cable(s) goes through right fork tube and under tank.
15 Sep 2015 06:46 - 15 Sep 2015 06:51
Just an FYI. Some models had various cable guides that are mounted at the upper triple clamp fork bolts.
My 650-CSR didn't come stock with them, but I added one on each side --- on the left for the clutch cable & on the
right to tidy up the handlebar control wires (the throttle cables couldn't be routed thru the guide).
A couple of examples that I installed.
clutch cable clamp guide ... & ... triple tree with guide
Last edit: 15 Sep 2015 06:51 by martin_csr.
- razmo99
15 Sep 2015 13:15
I thought the cabling might have gone as how you suggested it. When I get my new cables in I will make sure to route them correctly and while I am waiting might ask Kawasaki to see if they have the guides in stock.
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
- pete greek1
15 Sep 2015 13:21Why would you ask Kawasaki if they have them in stock, when the link that Martin gave you has over 10 in stock with lifetime warranty?? Peterazmo99 wrote: I thought the cabling might have gone as how you suggested it. When I get my new cables in I will make sure to route them correctly and while I am waiting might ask Kawasaki to see if they have the guides in stock.
- razmo99
15 Sep 2015 17:26
The part numbers are different and on a z500 the throttle cables go through the guide from what I can gather from the FSM. Another reason to ask Kawasaki is that I live in Australia and it will most likely be quicker and cheaper if Kawasaki has the part in stock. Lewis
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
- razmo99
15 Sep 2015 17:31 - 15 Sep 2015 17:32
Turns out that the part is discontinued by Kawasaki.
The only exact match I can find on Ebay is this.
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
Last edit: 15 Sep 2015 17:32 by razmo99.
- pete greek1
15 Sep 2015 18:15
The part in Martin csr's link will work. you might have to bend the ring a little bit to conform to the one in your e-bay link, & It's new & 1/2 the price
Pete
Pete
16 Sep 2015 02:54 - 16 Sep 2015 03:15I think I saw a few of those on eebbaayy USA, if that's any help.razmo99 wrote: Turns out that the part is discontinued by Kawasaki.
Priced around $15T & I think one or two had worldwide shipping.
search = kawasaki cable guide or cable clamp. or use KZ750 or KZ900 etc instead of Kawasaki
Last edit: 16 Sep 2015 03:15 by martin_csr.
