Sizes of Caliber Piston
- Garn
09 Sep 2015 15:15 - 09 Sep 2015 22:43
Could anyone tell me the caliper Piston diameter sizes of the following.
Kawasaki from brake(s). I asume dual disc front are same as single disc front.
Z1... ( 38.15mm from Z1owners forum GB) JB
Z2......
Z900-A4...... 42.85mm
KZ900......
Z1000-A1.....
Z1000-A2.....
RegardZ.
Ps. I have tried other forum sites will [strike]nil[/strike] one or two results to date.
Z2......
KZ900......
Z1000-A1.....
Z1000-A2.....
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
Last edit: 09 Sep 2015 22:43 by Garn.
Re: Sizes of Caliper Piston
10 Sep 2015 04:25 - 10 Sep 2015 05:22
I don't know the sizes, but you could use the cross-reference at Partzilla to expand the search.
According the x-ref the 76 KZ900-A4 has the same Fr Br caliper piston as a number of 70s models,
including several Triples, so maybe some of the Kawasaki Triples owners know the size.
Also, you might be able to use to the K&L catalogue to figure out what other models to check ---- some of them have the same caliper rebuild kit (KL 32-1289) as the 900, such as the 1980 550A. The pistons may not be interchangeable, but the diameters could be the same if the kits are the same.
KZ900-A4 Fr Br caliper piston --- 43048-006
Note: the Rr piston on some models is the same as the 900 Fr.
1969 H1 Mach III FRONT BRAKE (KH500-A8)
1970 H1-A FRONT BRAKE (KH500-A8)
1971 H1-B FRONT BRAKE (KH500-A8)
1972 H1-C FRONT BRAKE (KH500-A8)
1973 H1-D FRONT BRAKE (KH500-A8)
1974 H1-E FRONT BRAKE (KH500-A8)
1974 S3 Mach II FRONT BRAKE
1975 H1-F FRONT BRAKE (KH500-A8)
1975 S3-A Mach II FRONT BRAKE
1976 KH400-A3 FRONT BRAKE
1976 KH500-A8 FRONT BRAKE (KH500-A8)
1976 KZ750-B1 FRONT BRAKE
1976 KZ750-B1 REAR BRAKE
1976 KZ900-A4 FRONT BRAKE
1976 KZ900-B1 LTD FRONT BRAKE
1976 KZ900-B1 LTD REAR BRAKE
1977 KH400-A4 FRONT BRAKE
1977 KZ1000-B1 KZ1000 LTD REAR BRAKE ('77-'78 B1-B2)
1977 KZ750-B2 FRONT BRAKE
1977 KZ750-B2 REAR BRAKE
1977 KZ900-A5 FRONT BRAKE
1978 KH400-A5 FRONT BRAKE
1978 KZ1000-B2 KZ1000 LTD REAR BRAKE ('77-'78 B1-B2)
1978 KZ750-B3 FRONT BRAKE
1978 KZ750-B3 REAR BRAKE
1979 KZ1000-B3 KZ1000 LTD REAR BRAKE ('77-'78 B1-B2)
1979 KZ750-B4 FRONT BRAKE
1979 KZ750-B4 REAR BRAKE
1980 KZ1000-B4 LTD REAR BRAKE ('77-'78 B1-B2)
Last edit: 10 Sep 2015 05:22 by martin_csr.
- Garn
Re: Sizes of Caliber Piston
11 Sep 2015 01:57 - 11 Sep 2015 01:59
Thanks Martin_CSR. Also, received this from another forum.between all of you I think I have my answers.
Z1 Z1A Z1B - 43mm X 34mm.
Z900A4 Z1000A1 and KZ - 43 X 40.
Z1000A2 Z1R D1 and KZ - 38 X 40.
Z1R D2 D3 and KZ - 43 X 41.
REAR Z1000A1 A2 Z1R D1 - 43 X 22.
REAR Z1R D2 D3 - 43 X ??
ps interesting to note Kawasaki round of to the nearest lower number - 42mm, all listing outside Kawasaki round of other side - 43mm.
pss interesting to note some listings on FleaBaYe/online have many incorrect sizes.
psss interesting to note the UK Club boys must be on drugs, 38mm for a Z1? come on.
RIDDEN NOT HIDDEN. GGYF. THE MEMBER FOR MANDURAH.
ZORK WA
ZORK WA
Sydney Australia
Sydney Australia
Last edit: 11 Sep 2015 01:59 by Garn.
