Side-cover tabs
- daveo
Side-cover tabs
07 Sep 2015 08:50
What long-lasting fix can be applied to the side-cover tabs & rubber grommets to make them easier to put on and remove?
1982 KZ1100-A2/1170 sleeper 😀
- jackleberry
Re: Side-cover tabs
07 Sep 2015 09:07
Is grease considered long lasting?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- pete greek1
Re: Side-cover tabs
07 Sep 2015 09:25
You can use silicone spray, but by making them easier to remove, you will end up loosing one or both at high speed
so you should drill a small hole in the 2 top tab's ,of each side cover, that you can insert a small hairpin longer than the size of the grommet to keep them from flying off
Pete
Pete
The following user(s) said Thank You: daveo, Shabba
- daveo
Re: Side-cover tabs
07 Sep 2015 10:39jackleberry wrote: Is grease considered long lasting?
The grease I tried worked for about a week, and either evaporated or absorbed into the rubber grommet after that. Then the side cover was more difficult to remove than before, which put even more stress on the tabs.
Re: Side-cover tabs
07 Sep 2015 16:35 - 07 Sep 2015 16:36
What's the condition of the grommets? Perhaps they need to be replaced. ???
Z1Enterprises.com may have them. In the KZR archive someone used windshield wiper grommets from the auto parts store.
Last edit: 07 Sep 2015 16:36 by martin_csr.
- daveo
Re: Side-cover tabs
08 Sep 2015 02:04martin_csr wrote: What's the condition of the grommets? Perhaps they need to be replaced. ???
Great suggestion!
They are old and likely have lost some elasticity, but are not dried out and cracked. I may look into getting new ones, but thought there may be a method to prolong using these.
- jackleberry
Re: Side-cover tabs
08 Sep 2015 07:28daveo wrote:martin_csr wrote: What's the condition of the grommets? Perhaps they need to be replaced. ???
Great suggestion!
I suppose you could try soaking them in Marvel Mystery Oil or mineral spirits and wintergreen oil like people try to soften the airbox boots...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- davido
Re: Side-cover tabs
08 Sep 2015 08:45
How often do you take off your sidepanels anyway?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: pete greek1
- daveo
Re: Side-cover tabs
08 Sep 2015 14:10davido wrote: How often do you take off your sidepanels anyway?
At least once a day... :lol:
Seriously, I bought a NOS left side panel (cheap on ebay) and don't want to stress the tabs on it, since they are made so flimsy. The old right side-panel has two tabs repaired, and I fear pulling on it the wrong way may again leave one stuck in a grommet. :whistle:
- pete greek1
Re: Side-cover tabs
08 Sep 2015 14:30
I haven't had to remove my side covers for over a year
Pete
Pete
- daveo
Re: Side-cover tabs
08 Sep 2015 15:01pete greek1 wrote: I haven't had to remove my side covers for over a year
Pete
Ok, I admit it...I'm krazy about my KZ. Its the only toy I have that is always ready to play. :woohoo:
- Tyrell Corp
Re: Side-cover tabs
09 Sep 2015 04:27
To remove sidepanels I press the tab from behind, as the tabs tend to stress crack over time.
When respraying I repair these with plastic body filler - I build a wedge up behind the tab to hold it solid. A couple of mine are a bit loose so I have a small hole drilled in the top and it is cable tied to the frame under the seat, virtually invisible.
