KZ750e1 Fork Oil Change
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ750e1 Fork Oil Change
26 Aug 2015 17:24
#687246
Don't use a adjustable wrench. Get the right size. Can you get a socket on it?
  • Douglas.P
  • Douglas.P's Avatar Topic Author
27 Aug 2015 17:26 - 27 Aug 2015 17:26
#687394
Whelp. One came off when I gave it a real strong pull. The other one not so much. The metal of the cap ended up giving and now I have a damaged cap. Fml I'm done.
1980 KZ750e
Last edit: 27 Aug 2015 17:26 by Douglas.P. Reason: grammar
  • missionkz
  • missionkz's Avatar
27 Aug 2015 20:37 - 27 Aug 2015 20:45
#687425
If you can't get the lower and tube off the bike to work on it in a big ass vise.....Remove the handle bars, loosen both left and right camps and slide the tubes up as far as you can. Tighten all the clamp bolts. Use a propane torch with small flame to gently heat the tube, not the nut. Get a pipe wrench on it now with the teeth going the right way to dig in and yank that top cap bolt counter clockwise. You'll be buying a new cap bolt anyhow.
I have only had to do this one time in my entire life and it was a bike I got for free that the was laying down in a barn hard for 23 years!!! I simply can not imagine why yours won't come loose.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 27 Aug 2015 20:45 by missionkz.
  • pbmax
  • pbmax's Avatar
30 Aug 2015 12:18
#687874
Put a 24inch length pipe around that socket wrench handle. It will give you a lot more torque.
