Fork studs for MkII?
- kzrider
22 Aug 2015 10:54
One of the fork legs on my MkII has a bolt instead of a stud. I was going to find the part number and try to source a replacement stud, but neither my euro spec paper parts catalog nor kawasaki.com's online parts diagrams show the studs' part numbers. So I'm wondering if someone can tell me what the correctly part number is. Same as the earlier 1000s that use 8 35 studs? I didn't take one of the ones I actually have out to measure it, but it looks a bit longer than 35mm. Maybe 50mm?
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
- peter1958
Re: Fork studs for MkII?
22 Aug 2015 12:00
Is this it? Mine are the same as the exhaust studs.
www.partzilla.com/parts/detail/kawasaki/KP-92004-1009.html
www.kzzone.com/
22 Aug 2015 13:34
That's odd. Maybe someone switched a bolt instead. 35mm looks too short. 50 is more like it.
22 Aug 2015 14:37
I went out and measured one of the studs. I didn't take it out so it's approx. 47.46mm long.
- kzrider
24 Aug 2015 05:11
Thanks, I'll order some 92004-1009 then
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
