Brake Banjo Question
- skooterbum4real
Re: Brake Banjo Question
14 Aug 2015 14:24
I try to stay away from EBAY. There a last resort for me anymore. I got the banjo from a third party seller through Amazon. Amazon is good to make things right, but when dealing with a third party seller, things get a bit tougher.
I'm sure I'll get free return shipping on this, but I needed to know that I had a bad part first.
Thanks Steve !!
Thanks Steve !!
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
1976 KZ750 Twin
15 Aug 2015 19:10Jeff.Saunders wrote: Why buy from places who cannot help you get the correct part?
You may save a couple of dollars and end up with massive headaches...
You need 10mm x 1.25mm pitch.
When you measure bolts, you measure the THREAD diameter, Most threads will be slightly undersized, so a 10mm bolt will measure 9.85mm - this gives enough clearance to thread the bolt into the hole.
www.z1enterprises.com/ItemDetails.aspx?i...fS&item=GR992-03-32C
www.z1enterprises.com/ItemDetails.aspx?i...e&item=GR992-03-32CH
- skooterbum4real
17 Aug 2015 04:54
Thanks Patton, but I have the correct banjo bolt that fits the master cylinder properly. I'm having issues getting a "12mm banjo" to bolt to the master cylinder.
1976 KZ750 Twin
1976 KZ750 Twin
- pete greek1
17 Aug 2015 10:59
Look in your local phone book for a place that fixes & makes Hydraulic hoses for heavy equipment, that's where I had them make my S.S. braided brake line hoses, they'll have all kinds of banjo fittings in all different angles
Pete
Pete
The following user(s) said Thank You: skooterbum4real
17 Aug 2015 11:31
We use to have Hose Mart. It was bought by Alternative Hose but went out of business not long after.
- skooterbum4real
17 Aug 2015 11:49
Thanks pete greek1 !! Will check into that !!
1976 KZ750 Twin
1976 KZ750 Twin
17 Aug 2015 12:54
12mm banjo fittings might be a common Harley item
, as shown in this link I stumbled across in googling 12mm banjo bolt:
www.demonscycle.com/chrome-12mm-35-bend-...y-brake-fitting.html
Is just the 12mm banjo fitting needed (for attachment to an already on-hand brake hose), or is a complete brake line with integrated 12mm banjo fitting needed?
