Removing emblem push-nuts
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
12 Aug 2015 14:28
#685538
No eBay APP ID and/or Cert ID defined in Kunena configuration:unsure: What is the best way to remove the tiny push-nuts from the emblem tabs without damaging the tabs and/or side cover? I've got a new side cover coming, and want to reuse the KZ1100 label from my old one.
See push-nut image:
1982 KZ1100-A2/1170 sleeper 😀
Re: Removing emblem push-nuts
12 Aug 2015 14:47
#685539
When I removed mine I VERY carefully cut them off with a Dremel cutoff wheel. Those plastic pins they attach to are quite fragile, so whatever you decide to do be very careful. Ed
  • missionkz
  • missionkz's Avatar
12 Aug 2015 15:51
#685546
I have never been able to get them off easily.... scary.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Aug 2015 16:48
#685558
You'll have to pry them away with a tiny screw driver. If you bend them enough to get them off, you can flatten them and reuse them.
12 Aug 2015 17:06 - 12 Aug 2015 17:07
#685562
The problem I saw on mine was that the emblem's pins the push nuts are fastened to are very thin plastic and can easily break if you try to pry the nuts off (ouch - that sounds painful :laugh: ) I didn't have a problem finding replacement push nuts. Ed
Last edit: 12 Aug 2015 17:07 by 650ed.
  • martin_csr
  • martin_csr's Avatar
12 Aug 2015 17:25 - 13 Aug 2015 05:28
#685563
Using a dremel, I scored a diagonal line across each push nut, then pryed them --- mine were rusty & brittle, so they crumbled while prying. If need be you can cut deeper.
To install. The 650-CSR emblems are metal, so I cut threads onto the pins & secured the emblems with nylon lock nuts from the hardware store & put a small dollop of silicone caulk on each pin. I got the idea in the KZR Archives from skyman.
Last edit: 13 Aug 2015 05:28 by martin_csr.
