Center stand shaft
  • Dwight
  • Dwight's Avatar Topic Author
Center stand shaft
11 Aug 2015 14:44
#685434
I have a 1983 KZ750K1 (Belt drive). I finally tracked down a center stand but I can’t find an affordable shaft (part number 34019-016) for it. Would anyone have access to the dimensions so I could have one manufactured?
Thanks.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Center stand shaft
11 Aug 2015 16:57
#685447
If it's anything like mine, it's nothing more than a flanged shaft with a hole for a split pin on the opposite side of the flange. Look at your center stand - you will need a pipe the same diameter (or as close to as possible) as the hole that runs though the top. You can then weld a plate onto the end - just make sure that the plate is bigger than the centre stand hole on the bike. Then feed the shaft into place, and mark where the hole needs to go and drill it. If you don't have a welder, you could probably cut and fold out a flange, or even just use split pins on both sides.
1981 KZ750 LTD
