kz900/1000 spoked wheels
  • h2omonkey
  • h2omonkey's Avatar Topic Author
05 Aug 2015 21:14 - 05 Aug 2015 21:16
#684557
Can anyone school me on putting a spoked wheel on my 81 kz 1000p? Building a street/darg style bike and want to do a small tire rear end with 18 inch rim. I have an extended swing arm with 10" inside width. Was thinking I could use a 900 or 1000 hub and lace to a wider rim, so I could have the cush drive, is this doable? If I went with no cush drive, what should I look for in a hub, since I'm custom doing everything, caliber mounts, brakes, axle, does the hub realy make a difference as long as i get the sprockets to line up? Help, the more I read the more confused I get.
Also, is there a classified here, dont see that anywhere.
Thanks
Tony in Vegas
Last edit: 05 Aug 2015 21:16 by h2omonkey. Reason: added content
  • spdygon
  • spdygon's Avatar
Re: kz900/1000 spoked wheels
06 Aug 2015 07:00
#684593
As far as I know the spokes hubs only handle a 3.5 or 4" wide rim. On the inside of the hub their is a stamp that tells u.
That why every one get a gsxr or zx wheel for that application.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • NakedFun
  • NakedFun's Avatar
06 Aug 2015 17:58
#684700
Call Buchanan Spoke & Wheel. You will have to get custom drilled Excel hoops and spokes laced to stock KZ hubs if you are running stock KZ wheels.....
Metzler makes tubes big enough for modern radial tires.
It won't be cheap, but I have about $1500 in spokes and hoops alone to do what I did on my build bike.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • NakedFun
  • NakedFun's Avatar
06 Aug 2015 18:20
#684707
I used Harley Davidson hubs. Bought a bunch and collected data. Ended up designing spacers and a my own cush drive. It is in my build thread, but here is section where I am at with the cush.
www.kzrider.com/forum/11-projects/539557...200r-build?start=560
Cory
1976 Kawasaki KZ900
