1977 KZ1000A rear wheel options
  • peter_e
  • peter_e's Avatar Topic Author
05 Aug 2015 11:28
#684463
Does anyone know if there is an interference problem fitting a 1978 Police 1000 KZ1000C1 rear wheel (mag) in a KZ1000A swinging arm?
The reason I ask is that the p/n for the swinging are for the two bikes are different. And I think the cop bike ran larger/wider tires?
Before I fork over the cash for the cop bike wheel I would like to be pretty sure it will fit.
My second (may be preferred) option is to go with the standard spoked wire-wheel but I am having a hard time finding a sprocket hub (drive coupling) for that wheel. I posted a want-ad for one, so maybe with luck one will turn up.
I want to stay with the 18" rear wheel size. BTW - the LTD models with the 16" wheel have a different swinging arm p/n than the A model. Anybody know why? I thought the LTD wheel could be retrofitted straight into the A swinging arm. Am I wrong in thinking that?
Thanks.
Peter
  • spdygon
  • spdygon's Avatar
Re: 1977 KZ1000A rear wheel options
05 Aug 2015 20:25
#684552
Different Models ...Different p/n.
16" wheel fits... But the hub from the 16" mag won't fit the 18" spoke wheel. I did buy a police rear 18" wheel but never tried to fit it...the rim lip was difficult them the regular model Kz mags.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • peter_e
05 Aug 2015 21:11
#684556
Thanks spdygon.
I knew that the mag hub won't fit the wire wheel.
The cop bikes had run-flat tires size MR90-18 I believe.
Is the rim difference due to the run- flat tires?
Will a normal 120/90 or 4.25" tire fit the cop wheel?
