Pipe front inner Z1100 1981
  • WaldekPL
  • WaldekPL's Avatar Topic Author
05 Aug 2015 10:29
#684450
Hi!
My pipes are to exchange but in my country i can't find it. What other kawasaki have the same pipes ? Maybe kz 750 ? Or GPZ 1100 ? Please help! :(
Regards Paul
Kawasaki Z1100
  • TexasKZ
  • TexasKZ's Avatar
Re: Pipe front inner Z1100 1981
05 Aug 2015 12:15
#684483
If you are asking about the exhaust pipes that bolt to the engine and curve downward and under the motorcycle , then I am pretty sure that the pipes from any KZ1000 or 1100 built between 1981 and 2005 should fit. I am not sure whether or not the spacing is the same on the smaller engines is the same.
  • WaldekPL
06 Aug 2015 23:30
#684752
I mean the tube front suspension. Are there any other models had the same or similar tubes that can be mounted in a motorcycle ??
Kawasaki Z1100
  • MDZ1rider
  • MDZ1rider's Avatar
07 Aug 2015 11:51
#684796
According to the Kawasaki parts list:
This Kawasaki 44013-1064 PIPE-FORK INNER is used on these models and components:
1981 KZ1100-A1 Shaft FRONT FORK (KZ1100-A1-A2)
1982 KZ1100-A2 Shaft FRONT FORK (KZ1100-A1-A2)
1983 KZ1100-A3 Shaft FRONT FORK (KZ1100-A1-A2)
You may be able to adapt or modify inner fork tubes from another model. The models listed above are the only direct fit options.
Good Luck
