Sprocket alignment
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Sprocket alignment
26 Jul 2015 15:00
#682844
Best of luck to your wife.
The following user(s) said Thank You: Copbike1000
  • davido
  • davido's Avatar
26 Jul 2015 16:18
#682863
Sorry to hear that Daniel,
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
27 Jul 2015 08:24
#682966
so sorry to hear of your wifes diagnosis copbike1000.
fwiw,
i run the 6 inch wide 190mm rear tire on my 1980 z1r 3/8's of an inch off center with absolutely no ill effects.
this allowed me to run a 3/8's offset countershaft sprocket and "not" modify my frame at all.
someone asked about if top level racers can tell the offset?
let me relate this story to you of a guy that was a mechanic for a superbike team.
he said that when his rider came in he glanced at the chain to make sure it was looking okay.and noticed that there was aluminum shavings piled on top of the swingarm slightly in front of the rear sprocket area.
upon closer inspection he noticed the rear wheel had become "cocked" over to the side enough that the sprocket was cutting into the swingarm.
he asked the rider how the bike was handling and the rider said "fine it seems like it is cutting out a little in the upper rpm range,
but beside for that it was fine" lol.
that's my .02 fwiw,
27 Jul 2015 08:44
#682969
Would suspect that handling is already so compromised by swapping an extra-fat rear tire in place of the normal size stock tire, that adding a little offset on the rear axle is of negligible consequence.
Good Fortune! :)
  • Copbike1000
  • Copbike1000's Avatar Topic Author
  • Banned
  • Banned
27 Jul 2015 11:48
#682998
Funny stuff Leon. Thanks for sharing. Nice"chain saw"..........
  • Copbike1000
  • Banned
  • Banned
27 Jul 2015 11:57 - 27 Jul 2015 11:58
#682999
By the way, I Thank each and every one of you for the your kind works in regards to the situation with my wife. This forum is what I lean on when I'm down. I drown myself with ALL the knowledge you ALL contribute to this Forum and take my mind off of whats at hand.
My wife is VERY limited on what she can do with her time so she spends all day on Facebook. I've shared the fact (somewhere on the forum) that this Forum is my Facebook. So, Thank you ALL!!!!!!
Daniel
Last edit: 27 Jul 2015 11:58 by Copbike1000.
  • Copbike1000
  • Banned
  • Banned
04 Aug 2015 00:55
#684195
Swingarm swap out completed! Will torque everything in the morning and get the bike back on the ground. Will post pics once I dial in any last details.
  • 531blackbanshee
  • Vendor
  • Vendor
04 Aug 2015 06:39
#684217
woohoo!!!
  • Copbike1000
  • Banned
  • Banned
07 Aug 2015 23:59 - 08 Aug 2015 00:01
#684879
Thanks for putting a smile on my face Leon! I needed it. I am deeply sorry to say that my wife has passed away. I will be busy putting my life back together. Thank you ALL for your kind thoughts and support. Will be away from turning wrenches for a while, see you all when I return to my project Copbike1000
Daniel
Last edit: 08 Aug 2015 00:01 by Copbike1000.
  • 531blackbanshee
  • Vendor
  • Vendor
10 Aug 2015 06:45
#685217
my deepest condolences sir.
we'll b here.
  • kaw-a-holic
  • kaw-a-holic's Avatar
10 Aug 2015 09:22
#685241
That is truly horrible, my thoughts are with you and your loved ones My deepest condolences.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
