Changing chain and sprockets. Need help......
- skooterbum4real
22 Jul 2015 21:36 - 22 Jul 2015 21:37
I have a 78 kz650. I installed an 82 kz650 rear wheel and hub assembly onto my 78. I'm going to put new 530 pitch sprockets and chain on the bike.
The 82 kz650 donor bike had a 13t counter sprocket with a 33t rear sprocket. I believe I will need to run a similar gear ratio on my 78, now that I have switched out the rear wheel assembly. 95% of my riding is at 55mph or more, so I'm wanting to go up one or two teeth on the counter sprocket to slow the RPM's a bit at my cruising speeds.
Anyone have any idea's on the size of 530 sprockets I will need to compare to the 630 pitch 14t or 15t counter with a 33t rear sprocket ??
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
1976 KZ750 Twin
Last edit: 22 Jul 2015 21:37 by skooterbum4real. Reason: more info
The following user(s) said Thank You: Randombeat
- Tyrell Corp
Re: Changing chain and sprockets. Need help......
23 Jul 2015 04:10
13 tooth sounds really small to me, stress on the chain is increased a lot with a smaller front sprocket.
Your gear ratios remain the same whatever pitch chain you use, there are online calculators you can use. Remember these motors work more efficiently at higher rpms.
The following user(s) said Thank You: skooterbum4real
23 Jul 2015 05:05
630 33/13 = 2.538
630 30/13 = 2.308 (improved highway mpgs)(I think that's about as low as you'd want to go)
530 38/15 = 2.533 (closest ratio to stock 650-CSR)
530 38/16 = 2.375 (improved highway mpgs) <<<----
530 40/17 = 2.353 (a 17T may not fit)
A 16T 530 is about the same diameter as a 13T 630 (but slightly larger).
A 17T 530 may not fit ---- one guy said it's tight; another guy showed a pic in which he couldn't get it to work.
- skooterbum4real
23 Jul 2015 06:04
Any suggestions on the best chain manufacturers ??
1976 KZ750 Twin
1976 KZ750 Twin
- kaw-a-holic
23 Jul 2015 06:32skooterbum4real wrote: Any suggestions on the best chain manufacturers ??
DID or EK
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- skooterbum4real
23 Jul 2015 07:01
Thanks everyone for your help !!
1976 KZ750 Twin
1976 KZ750 Twin
- KZB2 650
23 Jul 2015 07:24 - 23 Jul 2015 07:32
I picked up a RK x-ring chain from Z-1 and ran reg oring RK for many years.......... Ran 16/41 for years and went back to the stock 16/42 for a little more out of the hole perf. Went on a 350 mile trip once and threw on a 17T front (41 rear) to lower the rpms..... did the trick but it really killed the acceleration......... must of fit but really can't remember how tight it was as I only did it the one time.
The 16/41 did very little maybe a 150 rpm drop and still out of the hole very good ......... maybe a 38-39 tooth rear for you ?? Could try a 17 tooth on your other 650 42T rear......to see what you think before you buy all new ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 23 Jul 2015 07:32 by KZB2 650.
23 Jul 2015 07:47kaw-a-holic wrote:skooterbum4real wrote: Any suggestions on the best chain manufacturers ??
DID or EK
Both are excellent. Another very high quality chain is Tsubaki. Ed
- bountyhunter
23 Jul 2015 12:42
Z1 used to have the lowest price on a really good X ring chain which was from one of the major makers, don't remember the brand. I have been running it for about 8 years now.
- OnkelB
23 Jul 2015 13:05 - 23 Jul 2015 13:30
I've been running 16/38 (530) on my 650 for the past 10 years or so, works really well for me. Lowers the 60 mph revs significantly without sacrificing too much acceleration. With a stock swingarm the 16/38 will work with a 102 link 530 chain (stock length for the 530 650s), you just need to pull the rear wheel back a bit.
As for manufacturers I use RK chains (XW-ring) on both my bikes, have nothing bad whatsoever to say about them.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 23 Jul 2015 13:30 by OnkelB.
- skooterbum4real
28 Jul 2015 19:43
Great !! Thanks for the info guys !! I'll be getting a 16/38 530 setup, and contact Z1 about the chain, and go from there.
1976 KZ750 Twin
1976 KZ750 Twin
