Wheel Alignment
  • loudhvx
  • loudhvx's Avatar
Re: Wheel Alignment
15 Jul 2015 07:35 - 15 Jul 2015 07:46
#680964
You probably already did this, but make sure you do the no-hands-test on a level surface... not necessarily flat, but not slanted. On a road with a crown, I go down the center of the crown. If there is a lot of crown, and you are not on the crown, the bike tends to pull toward the crown, if I recall (but it might be opposite). But on the crown it should go straight.
Last edit: 15 Jul 2015 07:46 by loudhvx.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Wheel Alignment
15 Jul 2015 07:39 - 15 Jul 2015 07:39
#680966
and then afterwords you and your buddy can play star wars with the fluorescent bulbs!
Last edit: 15 Jul 2015 07:39 by 531blackbanshee.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wheel Alignment
15 Jul 2015 07:50
#680970
Yeah and then call Al Gore and Haz/Mat to clean up the mess. :woohoo:
  • loudhvx
  • loudhvx's Avatar
Re: Wheel Alignment
15 Jul 2015 07:54
#680973
This is not a full alignment, but I center-punch a dimple in the center of the axle end, and axle head, and same with the swingarm. Then I makeshift a gauge with two sharp points... a plank with a sharpened coat hanger vise-gripped at each end will work. Adjust the coat hangers so they each fit into the dimple on the axle and swingarm on one side, then adjust the swingarm so they are the same on both sides. With this I found the casting marks on the swingarm were pretty accurate, but the smallest mark was hard to see, so it was easy to be off by one whole mark.
  • loudhvx
  • loudhvx's Avatar
Re: Wheel Alignment
15 Jul 2015 07:56
#680974
If you break enough bulbs 1000?, you might get enough Hg to make a carb sync.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wheel Alignment
15 Jul 2015 07:59
#680976
Don't let the Libs know that. :lol:
